The above message has appeared in the display window. What does it mean and how can I fix it, and/or does a new part need to be ordered.
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
You
have to replace your fuser assembly. (Assembly 115V fuser) (40X3569)
I suggest you contact Lexmark Technical Support for further diagnosis.
