20 Most Recent Lexmark C532n Color Laser Printer Questions & Answers
Replace tray Switch PCB located on the printer
Lexmark C532n... | Answered on Apr 05, 2014
The RAM soldered on card is bad. You need to replace the system
card.
Lexmark C532n... | Answered on Nov 30, 2012
I talked to Lexmark tech support they say We should replcae the display. Anyone knows how to clear the red LED error without having the view of the display?
Lexmark C532n... | Answered on Jul 19, 2012
This error indicates that the system board's on-board memory has failed.Try to power the printer off and wait 15 seconds. Then power the printer back on.
If this doesn't resolve the issue, I suggest you contact Lexmark Technical Support.
Lexmark C532n... | Answered on Aug 24, 2011
Unfortunately, there is no way we can reset the cartridge chip.
Lexmark C532n... | Answered on Aug 05, 2011
You have to Select Deactivate to turn Demo Mode off. In order to get off that mode. Should you need further assistance please contact Lexmark Technical Support.
Lexmark C532n... | Answered on Jul 29, 2011
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
A print quality defect in which pages contain random spots or splotches (click on the link to see sample http://bit.ly/mRX3qz) may occur after the replacement of a supply item or the clearing of a paper jam. If your printed output resembles the example shown, please do the following:
Print the Menu Settings page to check the levels of your consumable supplies (i.e. items such as toner cartridges and photoconductor units). Supplies that are at or near the end of their functional lives can cause various print quality issues independently of the operation of the printer.
If any of your other supplies are low, replace them to see if this resolves the issue. Instructions for replacing supplies can be found in the User's Guide.
It is always advisable to print the Print Quality Pages to get a detailed look at your printer's output. These pages allow each color plane to be viewed independently to determine if the issue is with one color (possibly due to a single supply item), or with all the colors (indicating a more general issue with the printer).
If the above checks show that everything is normal, the print quality issue is probably a temporary situation which sometimes follows supply replacement or paper jam removal. Printing 5-10 additional pages should allow the issue to clear up on its own.
If the print quality issue does not clear on its own, please contact Lexmark Technical Support
Lexmark C532n... | Answered on Jul 13, 2011
The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed.
You may also check the following:
1. The paper being used is within specification and has been loaded correctly.
2. Any previous jams have been completely removed.
3. The printing environment is within acceptable temperature and humidity ranges.
4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack.
5. If you don
Turn the printer off, wait about 10 seconds, and then turn the printer back on. If Performing Self Test and Ready do not appear, turn the printer off and contact Lexmark Technical Support.
Click the link http://bit.ly/nSKQ65 for quality print information. The list will show print samples and provided a link right below the image. The link will give instructions on how to go about the procedure.
For further assistance, please call Lexmark Technical Support.
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
Lexmark C532n Color Laser Printer Logo
57 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C Lexmark
  • C Lexmark
Most Popular Question
reset
  • Office Equipment & Supplies
