20 Most Recent
Lexmark C544dn Laser Printer Questions & Answers
Our lexmark c544dn has a
Pull back the fuser cover ( black upper area) and look for the jam beneath the black roller with paper sticking up - to pull it out
106.08 service printhead error lexmark
Please
click on the link provided below.
http://bitly.com/nIjA4L
If this
does not resolve the issue, please try to reseat the printhead cable.
Turn the
printer off, and remove the rear. Check the cable at JMIRR1 for shield. proper
connection to the controller board, the printhead cable for pinch points, and
the cable
or
connector for any other damage.
Won't use tray 2 when tray 1 is empty
Have you tried checking that tray 2 has the same paper type as tray 1. If your machine is network attached, you can access the embedded web server (where device settings can be adjusted) by entering the device IP address into a browser. Find the web address from the machine by going to menu (key icon), reports, then arrow over to network set up page. NSP is a 1 page report which will tell you the IP address. Go to a web browser and type in that IP address. Should take you to your device web page. From that page you can change the device settings (click on settings and then paper menu). Check to be sure that the same paper type is set for both tray 1 and tray 2 (and be sure that tray 2 is showing up on the list). I had to power the printer back on for it to recognize tray 2. Hope it helps
What does 200.04 jam error indicate?
Did you look the jam code up in the operators manual? might try going to the Lexmark web site and look up your model mite have a updated firmware that will fix that problem, also are you using paper that is authorized to be used with that machine? look up the spec in the op manual or web site, check the weight of the paper the paper draw rollers may be dirty clean with a small amount of soap and water. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
I have a Lexmark C544dn printer. I am getting a
Check the transfer belt and clean if necessary with Isopropanol (IPA), and a soft clean cloth. Also check the drum for the same. Handle with extreme care as these are fragile and expensive. If none of those fix the issue you may need to get the laser lenses cleaned professionally.
Toner out of ink. Can I bypass the color?
It is important to have toner in each of the toner cartridges, even if you don't use that color at all. The machine periodically `calibrates' by putting a very small amount on a belt in the machine. If it is unable to calibrate, it won't get ready.
Also, if you run an empty toner cartridge for too long, it will begin to leak waste toner, and cause major problems.
