Acer Aspire 5315 Notebook Logo
Anonymous Posted on Jun 25, 2012
Can`t install wireless
Router D-linkDSL2680
Anonymous
Level 3:
  • Acer Master 32,281 Answers
  • Posted on Jun 26, 2012
Anonymous
Acer Master
Level 3:
Answers
32281
Questions
Helped
7913484
Points
102259
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default adminpassword.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
2helpful
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
2answers
How to install a wireless router without installation CD
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
2helpful
2answers
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Can't install netgear router WGR614 IN AN DELL INSPIRON1594 LAPTOP
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
Can't connect pc to router
Your router is Wireless, so you can connect either with a RJ45 cable or via wireless network. With the wireless card installed in your computer you should be able to access the router after installing the wireless card's software. As an alternative, run a RJ45 cable from router to the network input on your computer. Again you may need to install software for the network card.
Installation of the wirless key
You can install/secure/encrypt your wireless network by login to your Router.
First login to your wireless Router. Refer the User Guide to get the exact steps to login to the wireless Router.
In gereral, 192.168.1.1 or 192.168.0.1 is the default Router login address. The defult username will be 'admin' and pasword will 'password'.
Go to the Wireless settings option in the Wireless Router configuration and enter/add the wireless password/passkey.
Good Luck!!!!!!!!!!!!!!!!!!
Trying to install a wireless router in my home
you have to configure the router on to the computer call the brand support they will guide you trough
3answers
How to setup the wireless router
If this is the first time you are trying to setup the router, might you need to install the router first.
otherwise my suggestion for you please contact your internet service provider / router company to get router configured to enjoy the secured wireless network.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
