20 Most Recent Linksys WRT160N Wireless Router Questions & Answers
You are using WRT160N router. This router has issues with the firmware.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Linksys WRT160N... | Answered on Sep 21, 2018
you could reset your router using settings such as reset or factory restore
1. first of all press the reset botton at the back of your router.
2. type the default gateway means ip 192.168.1.1 and type the defaut user name and password
3. setup new SSID and password and save the settings for more assistance contact
Linksys Tech support i hope this will guide you thanks
Linksys WRT160N... | Answered on Aug 29, 2018
If you forgot your Linksys password/network key. You need to reset your router.
I am going to suggest some simple steps for rest. Follow the direction.
1. Connect the router to power Outlet.
2. Use a pen or paperclip to reset the Linksys router.
3. Press the Reset Key Using pen or paperclip And hold it for 30-45 seconds and then release the reset key.
4. Now every setting has been reset and now you can change the router password and settings As you wish.
for Linksys router setup follow
How To Setup Linksys Wireless Router In 5 Min Fixingblog com
I hope this will help you.
Linksys WRT160N... | Answered on Aug 28, 2018
Linksys Routers are one of the best Home wireless routers. it has good security feature and better wireless length.
Check out this Post about Linksys wireless router setup.
Please follow steps and you will be able to setup Linksys wireless router in 5 min.
First of all you will have to configure your router to accept the iPhone. To do this you will need to go in to the router in your browser window and add your new device, it will ask you for your MAC number which can be found under the back cover of your iPhone or in your WIFI settings.
Then you will need to configure your router to either automatically assign an IP Address or use an allocated IP Address and use the same setting on your iPhone. Also, you will need to configure your router to either assign a DNS Server automatically or to use an allocated DNS Server and once again you will need to use the same settings on your iPhone.
Your IP Address is crucial in oreder for your iPhone to connect to your wireless network. Your DNS Server is crucial in order for your iPhone to access the internet through your wireless network.
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Linksys WRT160N... | Answered on Jan 31, 2018
i think this can be fixed . first reset the router settings and reset the printer also. and now try to setup the connection with advance settings as manual says . for more help contact brother
Printer Tech Support . i hope this will help thanks
Linksys WRT160N... | Answered on Dec 12, 2017
You will need to install an WIFI extender in the front room of your office which will then extend the signal to the rest of the out building. I've included a link on Amazon to a very simple, easy to set-up extender that you can set-up with the push of a button. Once you set-up/configured the extender near your existing router following the simple instructions, you can then move it to the front of your office. Best of luck!
Amazon com TP Link N300 Wi Fi Range Extender AP mode Supported TL WA855RE...
Linksys WRT160N... | Answered on Oct 12, 2017
The general rule for WiFi is to have the router placed at a reasonable height above the items that wish to use it. This is because the radio waves travel downwards
It was probably a repeater that was recommended to boost the signal.
Linksys WRT160N... | Answered on Sep 16, 2017
More info, you have a modem/router and another router? and what is "both" independently? and "while they are both connected" both what? If you just have one box the modem router, disable bridge mode or you just have a modem then with no routing.
Linksys WRT160N... | Answered on Sep 06, 2017
Be like that other Linksys router model, Linksys WRT160N router is always unique because of their wild, future-oriented functions and even smaller size.
You can call on the Linksys support number in order to get help from the expert to start running the router again. If the number you have dialed is not giving any response, you can go to the Contactforhelp to acquire the alternate contact number of technicians. Linksys setup customer support phone number Technical Service USA
Linksys WRT160N... | Answered on Jul 07, 2017
you are right, need cd for you lan card for it to work right,,but if you dont have it go to linksys web site and download the files you need
Linksys WRT160N... | Answered on May 31, 2017
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
ยทError Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Linksys WRT160N... | Answered on Apr 21, 2017
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Linksys WRT160N... | Answered on Apr 20, 2017
Call Linksys Technical Support. If they cannot help try this http://technicalsupport.blog.friendster.com
Linksys WRT160N... | Answered on Apr 03, 2017
Linksys WRT160N Wireless Router  Logo
1,043 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
WRT Linksys
  • WRT Linksys
Most Popular Question
password not working
  • Computers & Internet
