20 Most Recent
Zyxel Prestige 600WH Wireless Router (91-004-164001) Questions & Answers
I have zyxel p-600 series router and i managed to
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Blocking of wifi connections
Just enable wireless security and only give the password to those you wish to have access. You could also enable MAC filtering, but it's easy enough to defeat.
I don't have the documentation
Please try the following combination to access your router page
username: admin
password: admin
username: administrator
password: administrator
username: admin
password: password
password: password
Se desconecta llamo al soporte
PRUEBA USANDO EL CABLE ETHERNET DIRECO A LA PC.SI FUNCIONA ENTONCES DEBE CONFIGURAR TU ROUTER NUEVAMENTE. TE RECOMIENDO UN "RESET' DEL ROUTER.PARA HACERLO LOCALIZA UN PEQUENO AGUJERO EN LA PARTE POSTERIOR DEL ROUTER Y CON ALGUN TIPO DE OBJETO PRESIONA POR 30 SEGUNDOS.LUEGO VVE A HTTP://192.XXX.XX Y CONFIGURA NUEVAMENTE.
If you need more help come back.Post /thumbs / testimonial are welcome!
Hi. I cant seem to be able to log into my router
Try to reset the router to factory settings.Locate a small hole at the sides or back on the router.With a toothpick press the button until the router flash lights start.The try to start a new configuration.
I need installer for my
http://www.zyxel.co.uk/web/support_download_result.php
http://www.us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050627163311
You can go to the above mentioned websites for downloading the installer that you require. You got to select the appropriate model number. Only then it will provide you manual, firmware, software etc. for downloading.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
I just purchased a Netgear
WEP code will be 10 digits only...you need to type all the 10 digits together (without any spaces)... Try disabling netgear utility and use your default windows utility...It is not the problem with netgear....
When I type my IP adress onto the browser nothing happens.
Plug your laptop or wireless device directly to the router using a network cord. If you still cannot access your router through a hard wire connection, unplug the router for 45 seconds and plug it back in. Then restart your computer while it's still hard wired to the router.
Your router IP address by default should be 192.168.1.1. In order to make sure you are on the same network, click on start > run and type cmd or open a command prompt by typing cmd into the search field under vista and windows 7. Once you have a dos window open, type IPCONFIG and make sure that your IP address is 192.168.1.x. x represents any number that would be leased to your computer from the router. If you do not have that a 192.168.1.x ip address, DHCP might be turned off on the router and you will have to set up a static IP address through networking and connections managment, or network properties in windows xp.
In order to do this go to your control panel and into the networking icon. Find your LAN connection and right click and then left click on properties. Once it's open, click on TCP/IP and then click on properties. Change the raido buttons from Automatically Obtain to Manual and for the IP address type the following:
IP Address: 192.168.1.100
Subnet Mask: 255.255.255.0
Default Gateway 192.168.1.1
Click OK twice and try and connect to your router through the default IP address of 192.168.1.1.
If you had to configure your IP manually, make sure you go back in there and change it back after you configure your router for DHCP.
Have a great day.
Ipod is detecting network but will not connect
1. You will need to find the MAC address of the device and add it to the access list of the router in order for the device to be able to access the internet.
This is done in the router.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses. Done in the command line in Windows "run" if (Windows XP).
5. Set the Device/laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Try to log on to the internet.
This is for all routers to set up wirelessly.
I need power supply volts
The voltage is 12 VDC/12 VAC and the polarity is + to - and is reversed during operation. Please use a multimeter to test it's polarity before you connect it, otherwise you may make mistakes. If you are having problem using multimeter, i can help you..
Good luck.
Thanks for using FixYa.
Two access points don't work
1. check the distances of the access points.
If over 300 hundred feet you will loose.
2. check the main router to verify access points are configured in it.
My laptop cant fined the divice
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click Here for step by step instructions
