To scan documents for editing and saving as PDF file, you will
need to install the Lexmark OCR scan software on your computer. The Lexmark
scan software (no downloadable version) is only available on the installation
disc that came with your printer. If you lost the disc, please contact Lexmark
Technical Support Center for assistance. To install the OCR scan software from the printer installation CD:
SOURCE: lexmark p3150 ocr problem
If it truely has an optical character reader(OCR) built into the scaner it would not provide the software for it since the software is rather a large program an cost in excess of $100 just by itself.
Link to you model support page below:
http://support.lexmark.com/perl/support/support.cgi
To scan documents for editing and saving as PDF files, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available in the installation disc that came with your printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
I dowload lexmark x2650 in erternate and install in my computer, when I scan a document a massage apear 'an image-to-text(ocr) application is provided for you on your CD in the OCR folder.- select OK to cancel this operation.
-Install your OCR software.
-Try your operation again"
I try all three instruction but above message apear OCR Program Missing.
You may need to uninstall your existing printer software first. On your computer, go to Start > Programs > Lexmark 2600 Series folder > Tools > Uninstall. After the uninstall process, restart your computer when prompted.
When your computer turns back on, re-insert the printer software installation CD into your computer hard drive and re-install the whole program. Then try to scan again to verify that the problem is fixed.
