20 Most Recent
Lexmark P4350 All-In-One InkJet Printer Questions & Answers
What is Error Code 1102
If you get errors after refilling and then you clear the error!
And you still get errors occuring then this is a problem with the
cartridge.
1)The cartridges printhead may have burned out if it was run dry. (new cartridge is required)
2) No ink is coming out of the port hole! Try dabbing the bottom of the
cartridge on tissue. Ink should appear if not then use tissue with
Isopropyl alcohol and blot lightly until ink apppears.
3) If not ink appears then you may have an air bubble blocking the flow
of the ink. wrap cartridge tightly in plastic wrap holing in an up
right position whip downwards this will force air to the top of the
cartridge and open the port on the bottom. Remove wrap and try it out.
4) If the cartridge sat empty for a period of time before refilling you
are wasting your time. The ink is probably sitting at the top of the
cartridge and can not migrate to the bottom, in this case it may have
burned out.
In refilling of Lexmark cartridges:
Refill often and do not allow them to run dry. Running them while there
is not ink in the cartridge burns the print head out and the cartridge
will not work and you will get an error.
By refilling often the cartridge stays in good condition, you do not
run out of ink during a print job, and the cartridge will have a
prolonged life span.
Lexmark P4350 All in one - I barely used this
It's the OCR that is having problems. Make sure you have a good resolution when you scan, with good contrast. Black and white type in a nice typeface is usually 100%, but colored funky type on a colored background is going to have problems.
Printer Error
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. The procedures below will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Open the top cover of the AIO and remove both cartridges from the AIO.
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat step 4. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 5.
5
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions).
Defective Cartridge Check
To test the cartridge, replace it with either a new cartridge or a known good cartridge from another printer of this type. If the error message persists, proceed to Contacting Lexmark.
I cant use the ocr
Try to re-install the Lexmark OCR scan software using the installation disc that came with your printer to repair any possible corrupted files necessary for editing scanned documents.
Error message E1102
http://support.lexmark.com/index?page=content&productCode=&segment=DOWNLOAD&userlocale=EN_US&id=SO3536
