20 Most Recent Lexmark X2650 All-In-One InkJet Printer Questions & Answers
3answers
I just bought a lexmark x2650 printer it came
Here is the link to the exact manual you need:
http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf
10/11/2018 5:33:10 AM • Lexmark X2650... • Answered on Oct 11, 2018
2answers
Which website to download TWAIN or ISIS driver
Which versions do you want? ISIS Twain Driver ver1.1 1.2 1.3 1.7 1.8 1.9 2.3 2.5 etc Some support Win8 others do not
9/17/2018 12:45:24 PM • Lexmark X2650... • Answered on Sep 17, 2018
0answers
Lexmark X2650 3-In-One Printer/Scanner -
your problem may be ur power adapter has gone out... try replace by checking your input volts and ampere as well as output volts and ampere. you can use compatible also. if same problem occurs it might be the power supply area problem inside the printer
3/15/2017 8:41:45 AM • Lexmark X2650... • Answered on Mar 15, 2017
Hi my lexmark x2650 keeps
The EC5 error code indicates a short has been detected in one of your cartridges. Open the printer and remove both cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any errors. Open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to pop up. Or you can try to insert a different known working cartridge to determine if the other is faulty.
11/12/2015 4:09:12 PM • Lexmark X2650... • Answered on Nov 12, 2015
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
10/17/2015 4:27:24 AM • Lexmark X2650... • Answered on Oct 17, 2015
Is there a wireless print server available for this printer?
You can make any printer with a usb port wireless by adding a usb to wireless print server. Linksys makes them. Keep in mind that typically over this type of connection you will not be able to utilize scanning functions if it has them.
8/24/2015 4:25:53 AM • Lexmark X2650... • Answered on Aug 24, 2015
Printer will print a document but when it reaches halfway it stops printing. Only way to finish printing the document is to restart my pc. Why does this happen? Can this problem be resolved?
When you restart your PC does the printing continue from where it had abruptly stopped printing or does the printer print a fresh copy . In any case the clean the Print Cartridge Carry Assembly Mount Rod and try freeing up more space on your PC hard Disk for spooling the print data
6/29/2015 9:33:00 AM • Lexmark X2650... • Answered on Jun 29, 2015
Is this printer wireless? or do I have to use the usb cabl to print?
it seems that wireless is not supported, and you must use a USB cable. Check that the connectors are the correct ones; printer accepts a type B ('house') male connector (plug) If uncertain consult Lexmark support, or the manual for this printer. Information (including probably a manual) can quickly be obtained from the webpage All Products Printers MultiFunction Lexmark X2650 Lexmark The image shows two connectors (which may be on either end of a single cable, and what I think you need) lower is type B (printer end) , upper is type A (computer end, most commonly). Available in various lengths, you need USB 2.0 spec. 25639017-l5nz1zge0s5jbgweyu4yqzt0-3-0.jpg
4/10/2015 5:53:04 PM • Lexmark X2650... • Answered on Apr 10, 2015
0answers
Canon LBP 5100 does not print in B/W with an empty Color-Cadrige
That is the way that some color printers are designed. Just replace the color that is missing and do a deep cleaning of the ink jets and that should fix the problem.
3/10/2014 3:09:30 PM • Lexmark X2650... • Answered on Mar 10, 2014
Lexmark X2650 All-In-One InkJet Printer Logo
199 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
just bought lexmark x2650 printer came
  • Office Equipment & Supplies
