Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer than replace the print head.
Try the printer maintenance to clear the printer nozzles. After several deep cleaning attempts and there is no improvements in the printthen a new print head is required. A new print head maybe expensive and it maybe more cost effective to purchase anew printer. The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Hi, To ensure this is only an issue with the black, I recommend printing off a nozzle check. This will show you if this problem is effecting any of the other colours.
To print a nozzle please refer to chapter 12 page 115 of the manual,
If colours are missing I recommend cleaning the print head. You have two options for cleaning the print head a normal clean and a deep clean, start by doing a normal clean if required try doing a deep clean.
You can download the manual here:
http://www.fixya.com/support/p360568-canon_multipass_mp390_all_in_one_inkjet/manual-10203#
Try unclogging manually.Warning!!! Next steps may can make your print head not unusable. Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0050.
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
I removed the ink tanks then I removed the print head very carefully.
I rinsed the print head with the cleaner that comes with my refill
bottles, let it dry and carefully reinserted the print head. I "cleaned"
the nozzles and ran nozzle check and it worked fine.
I no longer trust this iP5000 printer for photos so I have purchased a new
Canon iP6700D which is great. I will use both printers...only using
the new one for photos only.
The main thing I have learned from my Canon printers is not to clean
the print heads as often due to that "Absorber almost full" message!
I still like the Canon for the ink capacity and separate tanks.
