20 Most Recent Canon Pixma iP2700 InkJet Photo Printer Questions & Answers
3answers
How do you repair error
It show your printer's ink absorver is almost full. So try to solve by using the following methods.
Here's How to solve Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use thanks.
6/28/2022 7:51:56 PM • Canon Pixma... • Answered on Jun 28, 2022
2answers
My canon pixma ip2770 colored
blank ink doesn't appear on paper although there is no notification of cartridge damage
1/17/2021 5:30:25 AM • Canon Pixma... • Answered on Jan 17, 2021
2answers
ERROR B200
canon ip 2770 eror b200
6/1/2020 8:38:21 AM • Canon Pixma... • Answered on Jun 01, 2020
3answers
Wholesale mini usb flash drives?
I know a website which is Committed to custom USB. http://www.customusbdisk.com/ Please open this and look for the products which you like.
3/11/2020 4:40:00 AM • Canon Pixma... • Answered on Mar 11, 2020
3answers
Where could I find a company who is personalized USB drives?
This company can assist you, check out their WEB site.http://www.qualitylogoproducts.com/
3/4/2020 4:42:28 AM • Canon Pixma... • Answered on Mar 04, 2020
3answers
Canon iP2770 paper jam but
press and hold the circle with inverted triangle buttons for at least 5 seconds.
printer will self-restart
after this error blinking is gone.
9/3/2019 2:33:11 AM • Canon Pixma... • Answered on Sep 03, 2019
4answers
Reset Printer Canon Ip 2770
how to reset my canon ip2770 printer
8/8/2019 10:18:53 AM • Canon Pixma... • Answered on Aug 08, 2019
3answers
Service error 5100 on Canon
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
7/26/2019 12:29:46 PM • Canon Pixma... • Answered on Jul 26, 2019
Problem with canon ip 2700 .....the printer show
Canon IP2700 6000 Error Error 6000 tells you that the paper feed roller is not turning, check for any foreign objects in the paper path, a flashlight and small mirror is the best way to look. yes.. i agree on this statement.. just try this one., its tested by my own experience., first turn off the power of IP2700 printer problem-canon-ip-2700-printer-show-vrjeudqyvin4dnjtypph1pzq-4-0.jpg then just try to turn the gear of paper feed roller in order to release the foreign objects.. , problem-canon-ip-2700-printer-show-vrjeudqyvin4dnjtypph1pzq-4-3.jpg if error persist, just try to turn the gear again until it works ok. pls send feedback if its work., salamat., mabuhay pinoy.
6/26/2019 5:05:24 PM • Canon Pixma... • Answered on Jun 26, 2019
How to solve error b200
The print head has a voltage fault. This is usually caused by the logic board going faulty and sending too much voltage to the print head. You will need a new print head and main logic board. This would probably cost more than the machine is worth. Buy a new printer.
4/20/2019 11:05:08 AM • Canon Pixma... • Answered on Apr 20, 2019
How could error code 6000 in ip2772 can be fix?
there is a problem in the gear during initialization of the printer, maybe there's a tiny piece of paper that cause the gear wont move, the best solution is to open the printer to see if there is a foreign object inside in it.. that's all
4/19/2019 1:22:12 PM • Canon Pixma... • Answered on Apr 19, 2019
The printer is not working. the orange light flashes five times.. how to solve this problem?
cartidge cannot be recognized ma'am. try to change the color cartridge ma'am. by: cris
2/23/2019 7:14:17 AM • Canon Pixma... • Answered on Feb 23, 2019
HOW TO FIX PAPER JAM CANON IP2770?
jam paper
2/3/2019 5:24:14 AM • Canon Pixma... • Answered on Feb 03, 2019
3answers
Error number 5200
eror usb.canon IP2770
12/1/2018 5:50:02 PM • Canon Pixma... • Answered on Dec 01, 2018
No black print comes out on my canon ip2770
make sure the cartridge has ink in it then soak the cartridge into cool water for 15 mins then use tissue paper to fully dry the chips and the printhead
11/26/2018 12:03:02 PM • Canon Pixma... • Answered on Nov 26, 2018
3answers
Canon pixma ip2770
Try installing the latest printer driver -
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
6/18/2018 8:48:50 AM • Canon Pixma... • Answered on Jun 18, 2018
Canon pixma IP 2770 error code 006
U have to download resetter file http://imadeitthisway.blogspot.com/2010/09/canon-ip-2770-reseter.htmlhttp://m4sjoysaja.blogspot.com/2010/08/how-to-reset-clear-counter-canon-ip.htmlI hope its working
6/4/2018 10:41:13 AM • Canon Pixma... • Answered on Jun 04, 2018
I have a Canon iP2700
Hi. I am almost sure that there is obstruction. Try this. Unplug the printer, turn it upside-down and shake it up and down . Maybe the foreign object comes out . If doesn't. Get technical support
2/26/2018 2:08:56 AM • Canon Pixma... • Answered on Feb 26, 2018
2answers
How to fix error 5b01 at ip 2770
Canon Printer fix error 5b01
7/26/2017 3:20:24 AM • Canon Pixma... • Answered on Jul 26, 2017
3answers
How to install ip2770
Install online is unusual way to do. People usually will download the driver first via internet (online). After installer driver software have been downloaded, we can run the file for installation.
If the installation success,we can connect printer to PC via cable data and we can start to use your printer.
You can download the driver from here :
Download Driver Canon Pixma iP2770
or from here :
Canon PIXMA iP2770/ iP2772 Windows All
Hope this help, and if you feel helped RATE please !
8/5/2016 1:39:31 PM • Canon Pixma... • Answered on Aug 05, 2016
Canon Pixma iP2700 InkJet Photo Printer Logo
536 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
service error 5100 canon
  • Office Equipment & Supplies
