Below I have provided you some quick info on the most common app to print with using your iPad. There are more so I will post the address which lists more.http://www.pcworld.com/businesscenter/article/195269/three_iphone_and_ipad_printing_apps.htmlPrinterShare is an awkward app to set up; besides
installing it on your Mac, you also have to register an account. After
that, on your Mac, you have to specify which printer (or printers) you
want to share, whether you want to hide your printer from search results
(more on this in a moment), find the remote printer as registered
online, select the printer (which is now displayed in two panes of the
main Mac application window, and then configure the printer (paper size,
"notify me on job completion," encrypt or not, and so on). In addition,
a third window appears when you click on the Mac application's
"incoming" button, and that provides you with a variety of options,
including setting default permissions (automatically download and print
from approved users, wait for approval, remove, and so forth).
This all makes sense, in a way, because PrinterShare is designed to
enable you to print remotely, over the Web, and to allow multiple users
to print to the same machine remotely. (For example, employees can all
remotely print to a shared printer.) However, there's no apparent option
for simply printing over a local network. And although you can choose
to hide your printer from search results (when you are searching for a
printer from the iPhone app), it seems that the only way for users to
find their own printer is to make it public and find it; then, once
that's done, they can hide it from search results. It's a confusing
process, in part because developer
Dynamix Software
attempts to protect users from having their printers hijacked by
unknown users. It seems, however, that the first option should simply
enable you to link your iPhone to your printer by using your user ID,
and that "searching" for printers should be a secondary option (because
it would probably be unnecessary for most users).
