Fix this Error - use an advanced registry cleaner for Windows that allows you to safely scan, clean, and repair registry problems with a few simple mouse clicks. Problems with the Windows Registry are a common cause of Windows crashes and error messages. By using PC tune-up utilities such as registry cleaners regularly, your system will be more stable, your software will run quicker, and your operating system will boot faster.
http://www.errorfixreviews.org/
or you can try this option Solution#1- If your printer does not show in your hardware list its means that problem belongs to data cable. Kindly check your printer's data cable and plug it properly.
Solution#2- Uninstall printer's software take a reboot and then reinstall its software and then attach your printer or during installation if installation requires.
Good Luck
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
