20 Most Recent
Canon MP560 All-In-One InkJet Printer Questions & Answers
My canon pixma MP560 is
Remove your black cartridge and check that the ink might be over flow or block.... so clean it up with soft paper... thanks
How do i change the
Open the front cover on
the printer. The print cartridges should slide on a conveyor belt from
one far end of the print chamber to near the center. There should be one
black ink cartridge and one color cartridge.Remove the cartridges
from the printer. This should simply involve grabbing and pulling the
cartridges out. There may be a flap holding the cartridges in place that
you need to flip up first. Or you may need to press down on the
cartridges to spring them out of place.Decide on replacing
the cartridges with a brand new ones or refilling the existing
cartridges. Refilling the cartridges can cost less money in the
long-term and reduce waste, while new cartridges will guarantee to work
and have the most ink up front.Refill the cartridges with fresh ink in order
to reuse them. With black cartridges, you need to drill or melt a hole
in the cartridge lid, while you will remove the lid to find the color
cartridge's holes. Inject the correct color ink with a plastic syringe
bottle. Reseal the lid on a color cartridge after refilling.Dispose of the
cartridges properly after you purchase new ones. Take the old cartridges
with you to whichever store you get the new ones from. Not only will
this help you find the correct replacements, but the store may also take
the old cartridges for recycling.Insert the new or refilled cartridges
into your printer. New cartridges likely have protective tape over the
print head that you'll need to remove. Run a test print on the computer to make sure that the
cartridges properly work Check to see if the
printer still reads the cartridges as being empty (if you are reusing a
refilled one). This will be due to a chip in the cartridges that the
printer reads for the ink level. It doesn't change just because you
refilled the cartridges. You must purchase an electronic device that will
reset the chip for you. Chris ThrashB52Computers
My canon mp 560 is reporting error 5b00. What does
press MENU button, SCAN button, COPY button, SCAN button.
wait a minute.
it may be enter into special mode: service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Canon mp560 communication error macintosh 10.5.8.
If all of your other equipment is working fine at the time you have issues with your printer then the folks at Canon are full of sh--! The issue is with the printer and you don't have to be a rocket scientist to come to that conclusion. Try to reset your printer to factory defaults to see if that solves the issue. And if you do not find the reset in your manual contact Canon to have them give you the code or reset protocol for your unit. Good luck.
Can't add my Printer Canon MP 560 to my PC at all.
If you have "upgraded" your operating system, it is likely that there is no current driver for your printer. This is a particular problem for users of Windows 10. Check the Canon website for updated drivers, but don't be surprised if your printer has become "obsoleted"
