D-Link DCS-5300 Network Camera Logo
Posted on Aug 22, 2011
The software for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Hl-dt-st dvd-rw_gsa-h11n ata
Try this: open 'Device Manager' find 'DVD/CD- ROM drives' open 'Properties' click 'Driver' and click 'Update Driver' hope it will help
tip
How To Identify Unknown Devices In Your Device Manager
Unknown Device Identifier enables you to identify Unknown Devices with the yellow question mark label in your Device Manager and reports a detailed summary including the manufacturer name, OEM name, device type, device model and even the exact name of the unknown devices. With this information you might contact your hardware manufacturer for support or search the Internet for drivers. Known devices recognized by Microsoft Windows will also be analyzed independent of the operating system.<br /><br />Supported Operating Systems include: Windows 95, Windows 98, Windows 98SE, Windows Me, Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008, Windows Vista, and Windows 7<br /> <ol> <li><a href="http://www.zhangduo.com/UnknownDeviceIdentifier.exe">Download Now (HTTP)</a> Size: 948KB (971,455 bytes)</li> <li>When download completes, install Unknown Device Identifier.</li> <li>Open the Unknown Device Identifier when the installation completes and wait for the program to finish Analyzing all devices on your system.</li> <li>When the Analysis is complete, find your Unidentified Device in the list of devices.</li> <li>Click the + sign next to your Unidentified Device, and use the Chip, Vendor and Device information to find and download drivers for your device.</li></ol>
on Mar 11, 2011 • Computers & Internet
Hello, When i on my lappy,it didnt start directly as usual and it will be suddenly off. And i need to on again and again by using Last Known Good Configuration or start your laptop in normal...
Press windows Key third key on bottom left and press R key at the same time. Type last known good configuration in box and hit run. This should clear it or you can set it back to a known last configuration as by date and time you knew it was working properly.
2answers
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Code 19 error on ibm windows XP PC...neither the DVD or Cd drive are recognized or able to perform any functions.
1helpful
Mobo problem
try new windows disk in the same cd rom drive, if not working try, your copy of windows in the new cd rom device(take it from your friend and asure that is working not baying first), if not try new copy of windows in second cd rom drive that you taken, if not flash your bios with newer release of your bios program, and try it from begining if not change your mb is gone.
18helpful
10answers
Pioneer dvd-rw dvr-k17a
i found the solution at microsoft support website, but i just found in portuguese, so im gonna try to explain how to solve it.
u need to go to start menu and then on the star search u need to search for "regedit"
when u are inside the regedit, look for this subkey "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
on the right side u need to del 2 subkeys
"upperfilters" and "lowerfilters"
close the regedit and restart the windows.
hope i can help u guys. it worked for me.
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
