20 Most Recent D-Link DCS-3220 Network Camera Questions & Answers
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
D-Link DCS-3220... | Answered on Dec 12, 2017
Can you view the stream in IE or IP surveillence or is it that you hit the camera in IE, the sign in box shows up (cause you put in a pasword), you put in the password, and it cannot connect and says retry.
Possible problems.....
The IP you are typing in is really not the IP of the camera (comes from the box being checked that says 'reset the IP on reboot') Use the installation Wizard to find the camera and it's IP.
Your firewall is blocking the stream. Try disabling it and reconnecting.
Your cameras IP is not in the range of the DHCP server of the router it's connected to. Review your router's DHCP list to see if the camera IP is in that range.
The password on the camera is corrupt. You will need to hard reset the camera and reset it back up from scratch to connect.
Worst comes to worse, you can always just hard reset the camera and start over.
D-Link DCS-3220... | Answered on Feb 25, 2015
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
D-Link DCS-3220... | Answered on May 30, 2013
DCS-3220 is fixed IP security camera !!
can't change its ip !!!
D-Link DCS-3220... | Answered on Jun 14, 2011
No there's not. The camera's video stream can only be viewed in Internet Explorer 6 or higher.
D-Link DCS-3220... | Answered on Apr 29, 2011
192.168.0.99 port 82
D-Link DCS-3220... | Answered on Mar 30, 2011
remove microsoft silverlight
D-Link DCS-3220... | Answered on Mar 07, 2011
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
D-Link DCS-3220... | Answered on Dec 15, 2010
hi...
please follow the instructions.
1.install the IP surveillance
2.Go to 'my network places'
start---->control panel---->my network places
3.You will see your device
4.Double click it you wil get a window like this...
5.Click on the configration button.
6.you wil get this page...
7.please select 'Advanced'(this is on the top)-------->Network(this on the left hand side)
8.In this page you have an option called as'1st recipient email adress'.please enter your adress and click on 'apply'
Now you can recieve the video clips. thanx
D-Link DCS-3220... | Answered on Jul 17, 2010
Web Camera’s have to be setup on the program they are to be used with. Just installing the
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
see and her to you.
B. Yahoo Setup:
(http://www.soft32.com/download_30.html )
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
1. After you start Windows Live Messenger, expand the view by clicking on the square on
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
Microphone
Speaker
Camera
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
D-Link DCS-3220... | Answered on Feb 16, 2010
You have a corrupt camera driver.
properly.
A. Skype Setup:
see and her to you.
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
D-Link DCS-3220... | Answered on Jan 13, 2010
I had a similar issue trying to feed a live stream to the web with a dcs 3220, I found that I had to use this IP configuration; Ip address is XXX.XXX.X.X/cgi-bin/video.jpg then use "jpg pull" from the web server. Hope this helps you let me know http://troyster.com
D-Link DCS-3220... | Answered on May 12, 2009
Sorry I have followup question before I can help you....
Are you trying to take snapshots using the button on the main screen when looking at it on the web page screen in IE or are you talking about hitting the snapshot button (looks like a tiny camera) in IP surveillence?
D-Link DCS-3220... | Answered on Sep 20, 2008
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
D-Link Computers... | Answered on Dec 19, 2019
D-Link DCS-3220 Network Camera Logo
Popular Tags
21 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DCS D-Link
  • DCS D-Link
Most Popular Question
change
  • Computers & Internet
