20 Most Recent
D-Link DCS-G900 Network Camera Questions & Answers
I have two DCS-G900 camera's
check whether they are using automatic IP addressing . it may be they are using the same IP in static mode so that one won't connect.
DCS-G900 stopped working
Probably has a corrupt driver.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html )
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on
top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or
friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window.
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
Wizard will appear to help you verify that your camera, speakers and microphone are working
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
Cannot factory reset DLink DCS-G900
i had the same problem and it was frustrating at first. You have to access your router and find the start ip address and the range and make sure dhcp is enabled. then plug the camera into one of the lan ports using the cable provided and plug the other end into the camera. then refresh the list of wireless clients in the router. Also if using a pre n router make sure that the broadcast is not mixed and is set to g mode. Only a g router will work or a router with g set to broadcast. i couldn't get the camera to work until i changed this setting. Anyways getting back to what i was talking about. When you see the list of clients you will see the camera listed on the client list. Write down the ip address example (192.168.1.108) and then on the computer (make sure you have another cable plugged into another lan port on the router and plugged into your computer) go into the dlink setup wizard. Press the search button the camera will appear on the list. Then click on the wizard and wait. It will say that the settings do not match there is an ip conflict or something to that matter do you want to change the settings click change settings and put the ip that the router configured. subnet mask is 255.255.255.0 and put the default gateway of the router which is usually 192.168.0.1 on most dlink routers but on the linksys i was using it was 192.168.1.1. After changing these settings it will let you into the camera configuration and after that you can unplug the cable and wait a minute or two. the green light should start blinking showing that the camera is connected to the router. Bingo your all done your camera is back to normal wireless function. You might have to unplug and reset the camera. If you have more than one camera make sure you unplug all the other camera's before configuring the first one. This will prevent any ip conflcts. Hope this helps you.
I have a DCS-G900 camara
http://support.dlink.com/products/view.asp?productid=DCS-G900.This is the d-link page for everthing related to your camera.this is a fixya vote blue(4)RICHARDM69
Cannot see camera on network. The link light just keeps flasing.
If you follow the instructions the guru sent you, you will learn how to set up your camera. After reading the comments I couldn't stop laughing. You probably won't find anyone to help you here after seeing how you rate good answers. Your best bet is to just hire a private investigator.
Connecting via IP to canera
If you plan on accessing your camera via the Internet you may assign a
domain name that's more memorable than your IP address with one of a number of
Dynamic DNS online services.
You have to assign an IP address for the camera on your home or work address. This is what will allow you to monitor your camera from anywhere in the world where there is internet access. Next follow this link and find a service:
http://www.technopagan.org/dynamic/#TheList
This page has a list of almost all the dynamic DNS online service providers. Many of them are free or donation based. The ones that are free or donation based are more for people that have a strong grasp of the concept. The pay services provide priceless customer service if you are new to networking or net based video cameras. I suggest you sign up with one of the pay sites for a month and milk their technical support team. They have 800 numbers and experts that will set the whole thing up for you then you just cancel at the end of the month and switch to one of the free providers. I hope this sets you in the right direction. If you need more assistance with this or any other technical issues feel free to contact me. Please remember to rate me Fixya for this insider information.
Thank you
George
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
