WFK2401 Bosch washing machine
This video will show you how to change the pump washing
machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
SOURCE: bosch wfmc3200 will wash but will not spin or
hi, this is a drain pump motor issue. i would check the wires leading to the drain pump and the control board. make sure the pump wires are connected and the control board wires as well. if the wires are connected, this will rule out a communication problem and confirm pump failure.
You can also do a break point test with a multimeter on the control board to make sure the control board is working correctly.
Concerning the locked door(washer locked)**. if the door is locked, this may be a control fault. test the door lock mech for its operational value to confirm this as well.
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
SOURCE: Bosch WFK2401 won't start error code 6
Open the panel at the bottom using a 2p coin by turning clockwise
Pull the rubber hose out of the holder and drain water into a container until stops
turn large plastic screw to the left for access to the pump
Clear away and debris bits of metal, plastic, etc that has stopped the pump.
Opposite of above to reassemble
Switch on and test... good luck!
SOURCE: Bosch WFF 2001 has finished a wash cycle but the
Do the following.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
SOURCE: BOSCH Maxx washing machine will drain and fill but
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug
off the wall first. Remove the front
lower panel, screws underneath. Be
prepared for water, drain out from drain hose.
Check filter for clogging, clean out.
Sometimes when the load is unbalanced & the machine cannot adjust
the load it stops. To avoid this make
sure your wash is mixed with big and small clothes.
If
this does not work remove the rear panel & check belt, should have half
inch ‘give’. Still not good, remove belt,
unscrew 2 bolts that hold the motor, unplug the motor connector, lever the
motor back with a screwdriver. Check the
motor brushes (at terminal end of motor), if they are any shorter than 1 cm
replace brushes.
Try
these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Hello Tony - Often when a unit does not spin it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose. Also you might want to clean out the coin trap, filter trap, of the unit for extra security. This needs to be completed about every 6 months to prevent any issues.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
6. Reach inside the coin trap and clean what is inside of it out.
7. Put the unit back together following the same steps backwards
