20 Most Recent
Bosch WFK 2401 Questions & Answers
Bosch WFK2401 Washing Machine will not power on. No lights.
The first thing you should try is checking the power supply cord and making sure it is securely plugged into the wall outlet. If it is and the washer still won't turn on, then you should check the house circuit breaker to make sure the outlet the washer is plugged into has not tripped. If the breaker is not tripped, then you may need to check the wiring harness between the power supply and the main board, as this may be the source of the problem. If the wiring harness looks to be undamaged, then you may need to replace the main board.
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
