I have a sdhc 4gb card with alot of pictures on it. i cant get them developed because every time it says memory card error. how can i get my pictures off my camera? it is not in locked position
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Make sure that you are using 2GB or less memory cards for your older camera. 4GB or higher SDHC will not work with an SD300. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Your camera was designed (2004) and manufactured (mostly 2005) before current generation SDHC cards became available. It will therefore be incompatible at the basic hardware level. There were some non-standard SDHC cards around in 2006 but your camera was never designed for those either.
Stick to regular SD cards, in theory your camera can handle 4GB maximum but the design team wouldn't have been able to certify compliance with that size of card as they also weren't available at the time. To be safe, stick regular SD cards with a 2GB maximum capacity.
Sorry there's no way for you to use your SDHC with your present camera but at least I hop that I've prevented you from wasting time and money on buying another incorrect memory card.
Please return the favour by taking a moment to rate my answer.
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others. http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
