20 Most Recent Acer CE-5330 Digital Camera Questions & Answers
What kind would you like to get? Cameras vary widely in size, weight, features, capabilities, ease-of-learning, ease-of-use, and, of course, cost. The best digital camera for one person is very unlikely to be the best camera for another person.
Visit your local library or bookstore. There are plenty of introductory books that discuss camera types and the trade-offs they offer.
Acer CE-5330... | Answered on Jan 28, 2015
Try these procedures.
Acer CE-5330... | Answered on Jan 04, 2013
The CE-5330 works with SD cards, not with SDHC cards. You need to use an SD card, 2GB and smaller.
The CE-5330 only works with SD cards up to 2GB in size. It will not work with higher-capacity SDHC cards.
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.
Make sure you have an SD card, 2GB or smaller. The camera will not work with higher-capacity SDHC cards.
Consider getting a card reader instead.
sur l'ecran probleme il y a des raies et mon appareil est bloque je ne peux pas tirer une photos merci
Acer CE-5330... | Answered on Sep 20, 2011
Hi there. I have a feeling that you put the batteries in wrong ,that's why the red light is flashing or the wrong type of batteries. (+ to + - to - ) is the correct way. Make sure the batteries are full when installed and don't mix old with new.
Acer CE-5330... | Answered on Jul 23, 2011
Hi.
Windows 7 does not need driver explicitly, its has driver inbuilt in it
Thanks...!!
Acer CE-5330... | Answered on Jul 04, 2011
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Acer CE-5330... | Answered on Apr 15, 2011
If you look at the SD card closely you will see a small white lever on the edge. This is the locking lever and is easily accidentally moved to the lock position. Once locked you cannot eraise the images. It's a safety feature. Just move the leaver to the unlock position and you can use it again.
Acer CE-5330... | Answered on Feb 09, 2011
Acer CE-5330 Digital Camera Logo
Popular Tags
36 questions posted
Top Acer Cameras Experts
Bill DeLisi
Bill DeLisi
Sumeet Sodhi
Joseph Hoffmann
Are you an Acer Camera Expert? Answer questions, earn points and help others
View Most Popular
Acer Cameras
  • Acer Cameras
Most Popular Question
find anywhere buy usb lead help
  • Cameras
