20 Most Recent Nikon D60 Digital Camera Questions & Answers
Hola,ha recibido alguna caida o golpe en el lado inferior izquierdo junto al display?
Si asi fue tiene el conector FPC cortado.
Otro la mas frecuente debe de reemplazar la unidad de secuencia SQ base plate unit.
Saludos
Nikon D60... | Answered on Jan 23, 2019
The D60 was released BEFORE HD SD cards came out. The 4 gig card MAY BE TOO BIG. HSD I think is the Nomenclature you may need a normal SD card. I think 2GB is as big as you can go but don't quote me.
Nikon D60... | Answered on Dec 02, 2017
First, you shouldn't take pictures in the raw mode unless you have the software on your computer that can read it and convert it. Second, the camera appears to be defective...it's new so why not take it back?
Nikon D60... | Answered on Oct 29, 2017
The pictures are blurry due to camera shake, which in itself is caused by the slow shutter speed. Try using shake reduction setting. To increase the shutter speed, raise the ISO rating.
Nikon D60... | Answered on Sep 06, 2017
Please set the MODE to P (Programmed Auto) In this mode YOU control the flash, not the camera. Inside where it is not bright. Set your ISO to 800 and take a photo indoors with low light. Then pop up the flash and do it again. P lets you take a photo with the flash down or UP it is the only mode I suggest most people should use. :)
Nikon D60... | Answered on Feb 12, 2017
All you said is that you have a Nikon D60. I can't help you if you do not ask a question.
1) WHAT IS YOUR QUESTION?
2) Which lens or lenses do you have?
3) Tell me ALL of the details surrounding the equipment failure or your question(s)?
Nikon D60... | Answered on Jan 03, 2017
Fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Nikon D60... | Answered on Nov 23, 2016
Did you recharge the battery? USB voltage is fixed at 5V. See if you can put the battery in and charge it without any computer involved. I fear that more than 5V was put into the camera and it may be badly damaged. I am not sure this is a guess.
Nikon D60... | Answered on Sep 10, 2016
Have a look on Google
Nikon D60... | Answered on Aug 10, 2016
There are several possibilities:
The card may actually be full. It's possible that you did not program the computer to erase the card after downloading the pictures from your last shoot. If that's the case, just format the card in the camera. You can check to see if there are images on the card by pressing the playback button on the rear of the camera. Camera must be "On" to do this.
The card may be corrupted. Again, try formatting. If this doesn't fix the problem, replace the card with a known good one and see what happens. If the camera functions properly, then you know it's a card problem.
If the above doesn't fix it, the card may not be making proper contact inside the camera. However, if that's the case you should be getting a "no card" error message. My D-90 simply won't operate without a card in place.
Finally, if none of the above help, contact Nikon tech support at www.nikon.com. I've found them to be very helpful.
Nikon D60... | Answered on Sep 29, 2015
If you are asking how to contact Nikon in the USA, phone 1-800-645-6687 between 9:00 am and 8:00pm EDST Monday through Friday.
Nikon D60... | Answered on Jun 08, 2015
most likely cause is failure of the motor in the SQ unit on the side of the mirror box. This ***** the shutter, raises the mirror, and operates the aperture unit. They're made in China, motors are **** This is a very very common problem, and the part is always on back order at Nikon. As Nikon has announced that they are going to stop selling parts - to anyone - in a couple of months you are probably better off sending it to them. Be prepared for a bill a little less than $200.
also if you pressed down really ******* the release to get it to fire, you may also have broken the release switch
Nikon D60... | Answered on May 29, 2015
Did you accidentally scroll to the shadows?
Nikon D60... | Answered on May 19, 2015
Look for "Noise Reduction" and "Active D-Lighting". Turn those to off individually and you'll see which one makes the most difference. Turn both off and you'll be able to shoot like mad. See page 55 and 178 of D60 owners manual to turn on and off. TC
Nikon D60... | Answered on Mar 31, 2015
If the camera has only been off for a few months, I would recommend that you take the camera and the battery to a camera shop, verify that the current battery is holding a charge and then check the camera with another battery.
Nikon D60... | Answered on Dec 26, 2014
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nikon D60... | Answered on Dec 25, 2014
454 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
nikon d60 now shows warning memory
  • Cameras
