20 Most Recent Canon PowerShot A610 Digital Camera Questions & Answers
Camera needs service
Canon PowerShot... | Answered on Aug 29, 2017
If you are too close to a subject the camera will not focus and therefore will not release the shutter.
Canon PowerShot... | Answered on Nov 02, 2016
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon PowerShot... | Answered on Dec 24, 2013
Does moving the switch make and difference?
Canon PowerShot... | Answered on Dec 21, 2013
No. The A610 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Check your setting. If you are taking real high resolution photos you won't be able to store as much on you memory card. Reducing photo resolution will help.
Canon PowerShot... | Answered on Oct 28, 2013
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Canon PowerShot... | Answered on Sep 07, 2013
Canon PowerShot A610 Digital Camera Logo
140 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
memory card error locked
  • Cameras
