Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of
freezer..you may see ice build up...melt ice with
hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with
paper towel...now you should see a hole in pan that leads to drain tube...pour some
hot water in pan..wait a couple
minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible
curtain wire or
electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the
fridge is because the water has been leaking into the
freezer and down the vent into the
fridge instead of
running into the drain hole...Please feel free to comment again if you have any other question. Mike
