Hi bufmanley,
If the convergence adjustment through your remote control didn't cure the symptom, this is an indication of bad convergence board inside. The most common parts affected is the convergence chip/IC and some of the resistor around. Best way and easy fix is to buy the entire board because sometimes it has a little difference only compared to buy the parts. But the problem is your board isn't available yet at the market. You will forced to buy the chip/IC and some of the resistor. If you don't have tools and test instrument to troubleshoot the problem, I would advice you to look for a proffesional to do the job for you, or send it to your local service center.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
the y sus problem on your tv. Please get it repaired or just replace it with new one.
Regards
Your advice sucks! Thanks for nothing!
The picture is doubled and offset. The best way to describe it would be to say that it looks like you are watching a 3D show without the glasses on. One of the images appears to be blue, the other image appears to be red.
Thank you!
Thanks!
