20 Most Recent Sony KP-46WT510 46" Rear Projection HDTV Questions & Answers
0answers
Sony 51 in Rear Projection Convergence Issues...
U have serious convergence board issues. If the solder connections on board go, that will definitely cause the hassle. If you are handy you can remove the convergence board and reheat every ****** connection on that board. Or if you check out google you can carefully put the board in an oven and use the bake setting for about 8 minutes at a temperature I forget.
5/3/2017 9:58:08 PM • Sony KP-46WT510... • Answered on May 03, 2017
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
11/3/2015 5:21:16 PM • Sony KP-46WT510... • Answered on Nov 03, 2015
0answers
3answers
Sont kp-46wt510 blinks 4 times
Four blinks is a "vertical stop error" I have a pdf file of the service manual and troubleshooting guide. If you want it,let me know where to send it.
12/21/2013 9:53:04 PM • Sony KP-46WT510... • Answered on Dec 21, 2013
How to connect antenna to sony kp-46wt510 without remote
Buy a used remote on ebay.
12/15/2013 9:43:16 PM • Sony KP-46WT510... • Answered on Dec 15, 2013
I have a new smart blue ray player and am trying to set it up using a hdmi cable to my sony KP-46WT510 tv and I have video but no sound?
Two things come to mind. !. are your cables plugged in right? Yellow->yellow, red->red, white->white? 2. Is the sound on the TV itself turned up?
11/28/2013 4:55:05 AM • Sony KP-46WT510... • Answered on Nov 28, 2013
Green will not align with others
The convergence has failed on your TV and will need to be repaired. You can call a shop or do it your self with a convergence repair kit from sites such as www.TvRepairKits.com . This is a failry common problem that all projection TV sets will have at some point.
5/2/2013 2:38:53 AM • Sony KP-46WT510... • Answered on May 02, 2013
My RCA HD52W59 shows double at the bottom of the screen Whats wrong can I fix it?
convergence issue and soldering under the high voltage transformer may fix this
12/22/2012 12:55:34 AM • Sony KP-46WT510... • Answered on Dec 22, 2012
How do I correct the problem of red, yellow and blue, triplicate colors blurring on my KP-46T510 46 in. Rear Projection HDTV Television
Its called convergence and this model should use two of the stk-392-560 chips----TVrepair.com sells kits for this based on model number but soldering is involved.11_3_2012_4_20_16_pm.jpgyour chips are similar to this one but will have different number on them.
11/3/2012 4:20:50 PM • Sony KP-46WT510... • Answered on Nov 03, 2012
8answers
Sony KP-46WT510 wont turn on
8 blinks means that the High Voltage Block is shorted - part# 8-598-955-32 (about $80)
11/1/2012 11:33:16 PM • Sony KP-46WT510... • Answered on Nov 01, 2012
2answers
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
10/22/2012 9:54:27 PM • Sony KP-46WT510... • Answered on Oct 22, 2012
Sony KP-46WT510 46" Rear Projection HDTV Logo
487 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
kp51ws510 posso usar o stk392 150
  • Televison & Video
