20 Most Recent RCA R52WH73 Projection Television Questions & Answers
Power supply failure
RCA R52WH73... | Answered on Dec 20, 2017
Lowest screen setting for ANY other screen can be an awlful default size. So if two or more screens to watch the computer are connected then this can happen.
RCA R52WH73... | Answered on Jun 13, 2017
Hello my name is willie. I see this problem alot on these units at the shop. And from what you describe. THis might be the very common problem with the fl231 fuse. this is a very fine fuse that blows due to bad solder connections. If u can solder and get this very special fuse then this is a very easy simple repair. But the first question you can answer to determine if this is true. is that when you go into customer menu then setup do you have a convergence option in the menu if you do not it is definatley this fuse. if you do then it will be something else like convergence power board. let me know if it is and i will see if i can talk you through the repair.
RCA R52WH73... | Answered on Mar 06, 2016
Thats a common issue with that chassis ITC222A which is always caused by the small signal board needing replacement. You should be able to get the small signal board from www.tvrepairworld.com
RCA R52WH73... | Answered on Jul 13, 2015
the Tv does not have a convergence menu like other models do .I.E. Toshiba, Panasonic ECT...If your having a Convergence problem then you have a Fuse gone out . you may have another problem too, but I'm betting tis just a Fuse and you can get a repair kit at WWW.Tvrepairkits.com they are affordable and have great support in helping you fix your tv
RCA R52WH73... | Answered on Oct 01, 2014
The link below may help you. It is for a similar television and may cover yours also.
http://www.manualowl.com/m/RCA/R52WH74/Manual/229723
RCA R52WH73... | Answered on Jun 19, 2014
check in the menue for sound options, make sure the internal amplifier box is 'checked'
RCA R52WH73... | Answered on Feb 25, 2013
Somehow this got posted in the TV area here, Look to see where the leak is coming from and better yet have a mechanic take a look, oil leaks can either be a minor repair or a major repair depending on where it is coming from.
RCA R52WH73... | Answered on Dec 15, 2012
Check to see if the auto convergence feature is still listed under the setup menu options or has it disappeared from the setup menu options. Let me know and I will assist you with what to do to repair the issue based on if the feature is still listed there or not.
RCA R52WH73... | Answered on Dec 09, 2012
shutdown issue and see previous answers.
RCA R52WH73... | Answered on Nov 08, 2012
see previous answers that this is a shutdown issue.
See previous answer that this is a shutdown issue---
Set has a "shutdown" circuit and will do this if a problem exists.
Not many customer service able parts here--common issues include bad solder connections are found around high voltage transformer--if you are not able to look for this consider a tech looking at it for you.
RCA R52WH73 Projection Television Logo
323 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
1998 volvo s70 leaking oil
  • Televison & Video
