20 Most Recent
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Questions & Answers
Red color off to the left
Thats a convergence failure. often you can replace the two Ics and associated resistors to repair the issue yourself instead of replacing the convergence board. But you can get the ICs and resistors from
www.tvrepairworld.com which includes free tech support for help installing the parts. They also have circuit boards for most models available if you choose to replace the board instead of trying to repair it.
3/23/2013 12:09:47 AM •
Samsung...
Answered
on Mar 23, 2013
Bought a convergence repair kit
Pico Fuses are either Green or Yellow ,they are in many different circuits near STKs,and Startup Power Supply boards.
Encompass Parts Distribution sells Parts and Boards for this Model.
Most of the time their is 2 resistors that need to be replaced 3.9ohms located in front of ICs.
First just replace the ICs ,you might not need to do anything else.
10/8/2012 7:41:10 PM •
Samsung...
Answered
on Oct 08, 2012
Samsung HCP4752W Convergence Problem
Each convergence IC has a fusible link going to the IC. On the foil side of the board you will see the fuse size, usually 3.15a. Check both with an ohmmeter, like you would check a normal fuse.
Replace the one that is open and that should take care of your problem.
Good Luck.
4/9/2012 5:32:32 AM •
Samsung...
Answered
on Apr 09, 2012
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
3/28/2012 11:20:12 AM •
Samsung...
Answered
on Mar 28, 2012
