20 Most Recent JVC AV-48WP30 48" Rear Projection Television Questions & Answers
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
JVC AV-48WP30... | Answered on Nov 28, 2017
@Goonnowthenn
"wont light up... ..what have I zapped.."
Hi G...
As long as you didn't leave stray cables dangling around from the removed DVD, there should not be any short circuits.
If you did, something may have touched where it shouldn't and shut down or blown the electronics.
Another cause could be the self-protection firmware detects a fault, due to wrong amperage or an 'open circuit' condition.
ie: The missing DVD module or part could be confusing the TV.
JVC AV-48WP30... | Answered on Oct 16, 2017
Best choice here is to just replace the TV.
JVC AV-48WP30... | Answered on May 12, 2017
it is the problem of unexpected
JVC AV-48WP30... | Answered on Apr 09, 2017
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
JVC AV-48WP30... | Answered on Mar 24, 2017
If you have no video and its making a popping noise its mostlikely shorted convergence circuits. Contact www.TvRepairKits.com and ask them to make you a kit for chirping sets.
JVC AV-48WP30... | Answered on Nov 18, 2016
The recommendation of the manufacturer is to replace the ICs with the same part number. In this case, use hte STK 392-110. Some people "upgrade" to the STK 302-150 because it can handle more power. The added power handling will not significantly increase the time of the set at all. This is your call. Either IC will work as the pin-out is the same for both.
I'd use the original part number.
Dan
JVC AV-48WP30... | Answered on Oct 18, 2016
must be the power supply or a fuse ,does the fan come on and a orange light beside the power light flick on and off?if so count the blinks before it shuts off could be the lamp program also,just refer to the manual that you can download freee from JVC M anuals and count the amount of orange flickers.
JVC AV-48WP30... | Answered on Sep 27, 2014
go through menu untill you find screen page and change aspect ratio setting use up and down volume to change it
JVC AV-48WP30... | Answered on Aug 23, 2014
what are you asking?how to change,if you have the remote use theater pro or natural cinema for movies ,and also split screen,withoiut remote manually scroll to picture page and use up and down settings to set it on choice
Easy answer, most of the time verticl lines are due to dirty lenses and bulbs inside of the tv, This can be resolved 1 of two ways: either you can open the back of the tv and clean both the lenses and bulbs with a special lens cleaner or you can pay a tv repair man to do it they usually charge anywhere from $60.00- $150.00.
JVC AV-48WP30... | Answered on Aug 13, 2014
look like attached photo?
SD TECH
JVC AV-48WP30... | Answered on Mar 02, 2014
JVC AV-48WP30 48" Rear Projection Television Logo
483 questions posted
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
correct part number
  • Televison & Video
