20 Most Recent Toshiba 42H81 42" Rear Projection Television Questions & Answers
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Toshiba 42H81... | Answered on Aug 10, 2017
Please go to below website you can get the codes to programme out remote.
http://www.urc.philips.com/
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
9f4dce2.jpg 4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
Toshiba 42H81... | Answered on Jul 01, 2016
check the ff speaker,input/output amplifier , pre amplifier, audio signal from tuner or srs settings if possible
Toshiba 42H81... | Answered on Jan 05, 2015
old tv. don't put anymore money in it. get you a nice flat screen. not work it being a projection. jmo
Toshiba 42H81... | Answered on Oct 08, 2014
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Toshiba 42H81... | Answered on Feb 11, 2014
Is it the correct rmote??
Contact Toshiba Tech support. Call Shopjimmy .com
Toshiba 42H81... | Answered on Nov 14, 2013
try to see the manual of that tv or try to ask help of tecnicians thanksss and hope to help you
Toshiba 42H81... | Answered on Nov 08, 2013
Hello, that is a Toshiba only item, you will have to contact them. tks
Hello, to replace the ir sensor, unplug the set, remove the speaker cover on the front, remove the screws around the plastic push button assembly, carefully remove the wire connections (plug connectors) off the assembly and remove the screws on the back side of the board and remove the board and replace it with the new assembly, re install the screws on the board, attach the wire connections and re mount the push button assembly and replace the speaker cover....tks
Toshiba 42H81 42" Rear Projection Television Logo
507 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
replace stk392 110 ic 39 s in toshiba
  • Televison & Video
