E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Problem IR 3300 Error E000064 000
iam getting a error code E000064-0000 in my canon 3300
how to slove the problem
I am getting error code E000-000 in my canon 2004
