20 Most Recent Canon imageRUNNER 3300 All-In-One Laser Printer Questions & Answers
ir 3300 my error 0000000
Canon... | Answered 15 hours ago
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
Canon... | Answered Yesterday
IF the LED screen shows "TONER IS NEARLY OUT", the "ERROR" light will constantly blink and the "ENERGY SAVER" Feature is disabled YET printer copy-fax-scan operation working properly, the solution will be to replace the toner cartridge. This will solve these issues.
Canon... | Answered on Sep 17, 2019
. enter SAV- Copier-function-clear-error
Canon... | Answered on Jul 26, 2019
error e000007-0000
Canon... | Answered on May 29, 2019
check the finisher
Canon... | Answered on Mar 17, 2019
Image Runner 3300 or (iR3300) copiers do not come with print/scan OPTIONS installed. These functions must be enabled by installing the correct 'kit'....same with fax option...again, these were 'options' when this machine was introduced, no print, scan, fax,...unless options were added to it. Yes, the buttons are there, however.....
Canon... | Answered on Dec 13, 2018
top glass error or ccd,or mirror adjustment
Canon... | Answered on Dec 04, 2018
canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???
NO KEY IS FUNCTIONING NOW.................
mail at chandaxerox@gmail.com
Canon... | Answered on Nov 13, 2018
error e000021-0220
Canon... | Answered on Nov 04, 2018
Remote UI probably has not been installed on copier. Get a technician to come out and use SST to load RUI onto your copier. They should upgrade firmware to latest version at same time.
Don't forget you can also pull scan over the network using Canon Network ScanGear Tool in case you would like to scan.
Canon... | Answered on Oct 16, 2018
ERROR CODE E000602-0003 what i do
Canon... | Answered on Oct 13, 2018
Fixing temperature abnormal rise
1.Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. 2.Check connection of the Connectors (Thermistor Connector and AC Connector). 3.Replace the Fixing Main Thermistor (Film Unit). 4.Replace the Fixing Assembly. 5.Replace the DC Controller PCB (PCB4)..
Canon... | Answered on Sep 24, 2018
Clean rollers of debris
Canon... | Answered on Sep 23, 2018
RERA registration is applied on all real estate projects therefore all builders, real estate developer and entity associated with the real estate project is required to submit RERA registration application with the local authority on their official portal. RERA registration in Gurgaonis introduced to eliminate the chances of any discrepancy, irregularity in real estate development industry. We are the leading consultants for RERA registration in Gurgaon with expert professionals to handle the issue.
https://www.gsbtaxation.com/in/rera-registration-in-gurgaon
Canon... | Answered on Sep 19, 2018
E051
0000 At start-up, home position is not detected when the horizontal registration
assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration
motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
Are the connectors of the horizontal registration home position sensor and
the horizontal registration motor connected?
a. DC controller PCB (J304) relay connector horizontal registration
b. DC controller PCB (J304) relay connector horizontal registration
motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping
with the motor rotation?
YES: a. The horizontal registration assembly is out of place because of
damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the
presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the
sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller
PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty. Replace the motor.
NO: Replace the DC controller PCB.
As You can see, is better to call service.
Hope that helps!
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
1,163 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
copier canon ir3300 error e000003 0000
  • Office Equipment & Supplies
