Posted on Jan 08, 2011
Brand new hp c310 only prints blank pages. It is connected correctly. Tried powering off unplugging power and usb cables and reconnecting and powering back on no luck. ????? I have seen several similar posts on various boards with no solutions found to solve the problem.
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Jan 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
8511
Points
91
1) Try using different print cartridges. If they don't work and the printer is new, return it to the store and get a replacement.
Color ink problem
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start (c01827528.gif ), click All Programs , click the HP folder, and then click the icon for your HP printer (c02053172.gif ). The printer software opens.
  2. In the printer software, double-click Estimated Ink Levels . The Toolbox opens.
  3. Click the Estimated Ink Levels tab to display the estimated ink level of each cartridge. Figure 1: Estimated ink level indicator c02752297.gif Image: Estimated ink level indicator.
  4. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  5. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the printer Resetting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer.
    NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the rear of the printer. Figure 2: Disconnect the power cord from the rear of the printer c01869581.gif Image: Disconnect the power cord from the rear of the printer.
  3. Disconnect the USB cable from the rear of the printer. Figure 3: Disconnect the USB cable from the rear of the printer c01850063.gif Image: Disconnect the USB cable from the rear of the printer.
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 4: Reconnect the USB cable to the printer c01868577.gif Image: Reconnect the USB cable to the printer.
  6. Reconnect the power cord to the printer. Figure 5: Reconnect the power cord to the printer c01869582.gif Image: Reconnect the power cord to the printer.
  7. Press the Power button (c01602202.gif ) to turn on the printer.
  8. Try printing again.
Solution three: Restart the computer Restarting your computer might resolve the issue.
  1. Save the latest changes to your files, and then close all your open programs.
  2. Click Start , and then click Shut Down . A dialog box opens.
  3. Select Restart . Most computers turn off, and then turn on again automatically.
    NOTE: If a dialog box opens with a message that it is now ok to turn off the computer, press the power button on the computer to turn it off. Then press the power button again to turn it on. After a few minutes, the computer is ready to print again.
  4. Reopen the file that you want to print, and then try printing again.
Solution four: Check for blank pages in the print preview If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
  1. In most programs, click File , and then click Print Preview . If the program you are using does not have this option, consult the program manufacturer.
  2. Review the print preview for blank pages.
  • If the print preview reveals blank pages, delete the blank pages in the document, and then try printing again.
  • If the preview contains no blank pages, continue with the next solution.
Solution five: Check the USB cable If the printer connects with a USB cable, a faulty connection might cause the issue. Follow these instructions to check the USB cable.
  1. Make sure that the USB cable inserts all the way into its port on the rear of the printer. Use some pressure to push it in all the way. Figure 6: Insert a USB cable into the rear of the printer c01868577.gif Image: Insert a USB cable into the rear of the printer.
  2. Make sure that the USB cable inserts all the way into its port on the computer. Use some pressure to push it in all the way.
  3. If the issue persists, try replacing the USB cable with a known good cable.
Solution six: Check the printer settings on the computer Issues with the printer settings on the computer might cause the printer to print blank pages. Follow these steps to check the printer settings on the computer. Step one: Check the default paper settings Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)). Follow these steps to check the default paper settings.
  1. Click Start (c01827528.gif ).
  2. Click Printers and Faxes . The Printers and Faxes folder opens.
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . The Printing Preferences window opens.
  4. Click the Paper/Quality tab, and then compare the settings in the Paper Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Paper Size drop-down menu, change the setting:
    1. Click the Paper Size drop-down list, and then select the size of the paper that is in the tray.
    2. Click Apply to save the settings, and then click OK to close the Printing Preferences window.
Step two: Print a test page Follow these steps in the order presented to print a test page. A test page might help determine if the printer installation caused the problem.
  3. Right-click the printer icon (c01532298.gif ), and then click Properties . The Properties window opens.
  4. In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page. Figure 7: Example of Windows XP Printer Test Page c01532301.gif Image: Example of Windows XP Printer Test Page.
  • If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
  • If the page is blank, continue to the next solution.
Solution seven: Print from an alternate program Follow these steps to try printing from an alternate program, such as Microsoft Notepad or WordPad, to determine if the current program is causing the issue.
  1. Browse to the location of your saved document, right-click the file, and then click Open With . A window opens with a list of programs.
  2. Select a program other than the program you are currently using to print the document.
  3. Open the file in the program, and then check the contents.
    NOTE: Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense.
  4. Try to print the file:
    1. Click File , and then click Print . The Print window opens.
    2. Select your HP printer from the Select Printer drop-down menu, and then click OK .
    If successful, the printer prints exactly what displays in the program window.
    • If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance.
    • If the document still prints blank pages in the alternate program, continue to the next solution.
    • here are a couple things you can try hope this helps you
3helpful
HP Officejet 8500A connected via wireless network to a Mac only prints blank pages sent from the computer. It eprints docs sent via email, and it prints test pages. The only communication error seems to be...
following these steps for the Macintosh operating system, versions 10.5, 10.6, and 10.7.IMPORTANT: You must follow these solutions in the order presented to resolve the issue. NOTE:Some of the following solutions require you to restart the computer. Consider bookmarking this page on your Web browser, so that you can reference it after restarting the computer.Solution one: Check the ink levels To allow for full use of the cartridges, some products continue to print even after the cartridges are completely out of ink.Follow these steps to check the ink vels.NOTE:Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low-ink levels, consider having a replacement cartridge available to avoid possible rinting delays. You do not need to replace cartridges until print quality becomes nacceptable.Click the Apple icon ( ), and then click System Preferences .Click Print & Fax in Mac OS X 10.5 and 10.6, or click Print & Scan in OS X 10.7.In the Printers section, click the name of your product. Your product displays in the right side of the window.Click Options & Supplies , and then click the Supply Levels tab NOTE:Depending on the product, the estimated ink level indicators might vary in appearance. Ink levels are estimated. If the levels are low or empty, replace and retry the print job again.Try printing again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution. solution two: Restart the printer Restarting the product might clear some issues and allow it to function correctly again.Press the Power button ( ) to turn off the produc Pressing the Power button might not turn off the product. This might happen if the product is in an error state. Continue with these steps regardless.isconnect the power cord from the rear of the product.Figure 26: Disconnect the power cord Disconnect the USB cable from the rear of the product.Figure 27: Disconnect the USB cable Wait 30 seconds.Reconnect the USB cable to the product.Figure 28: Reconnect the USB cable Reconnect the power cord to the product.Figure 29: Reconnect the power cord Press the Power button ( ) to turn on the product.Try printing again.If these steps resolved the issue , you do not need to continue troubleshooting. If the issue persists , continue to the next solution.Solution three: Restart the computer Restarting your Macintosh computer might resolve the issue.Close all open programs. Make sure that you save the latest changes to your files.Click the Apple icon ( ), click Shut down... , and then click the Shut Down button.After the computer shuts down, wait for ten seconds, and then turn the computer on again.Reopen the file you want to print, and then try printing again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution. solution four: Check for blank pages in Preview If the product prints all the pages in the print job correctly, but adds blank pages to the printout, check for blank pages in Preview.From the program you are using to print, click File , and then click Print .Click the PDF button located on the lower-left of your screen.Click Open PDF in Preview .This will save the document as a PDF and open in Macintosh Preview.Review the content for blank pages. Click File , and then click Print .Make sure the correct product model is selected, and then click Print If the print preview reveals blank pages, delete the blank pages in the document, and then try printing again.If the print preview contains no blank pages, continue with the next solution. olution five: Check the printer cables If the product connects with a USB cable or an Ethernet cable, a faulty connection might cause the issue. Follow these steps in the order presented to check the cables.Make sure that the cable connector inserts all the way into its port on the rear of the product. Use some pressure to push it in all the way. If an Ethernet cable connector has a broken clip, replace the cable.Figure 30: Insert a USB cable Figure 31: Insert an Ethernet cable Make sure that the cable connector inserts all the way into its port on the computer. Use some pressure to push it in all the way.If the issue persists, try replacing the cable with a known good cable.If these steps resolved the issue , you do not need to continue troubleshooting. If the issue persists , continue to the next solution. Solution six: Check the printer settings ssues with the print settings on the Macintosh computer might cause the issue. Follow these steps to check the print settings.Open the program you are using to print. Click File , and then click Print Click Paper Size: . Make sure the correct paper and paper size are selected and that the settings match the paper loaded in the product.Check all settings, making sure there are not more pages on the list than you intend to print.If these steps resolved the issue , you do not need to continue troubleshooting If the issue persists , continue to the next solution.Solution seven: Use TextEdit to print Follow these steps to try printing from TextEdit to determine if the current program is causing the issue. Click File , and then click New Finder Window .Click Applications , and then double-click TextEdit .Click File , and then click Print Make sure all settings are correct, and then click Print .If the document prints successfully in TextEdit, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance.If the document still prints blank pages in the alternate program, continue to the next solution.solution eight: cervice the product If you have completed all the preceding steps and are still experiencing a problem, service the product.Determine if your product is in warranty
1helpful
My hpf44880 printer prints out blank sheets of paper what do I need to do to get it to print with ink on the paper?
please follow these steps:
1.please print a test page from printer(hold down power and cancel(red X)buttons for 3 seconds together and release both of them..it will print a test page
2.if it is blank :please take out the cartridges.
clean the metallic contacts with lint free cloth
clean the ink cartridge slots with a cutip
disconnect usb cable
unplug the power cable from the back keeping cartridges out
hold down power key for 30 seconds
reconnect power cable
reinstall the cartridges
3.print a test page again from printer if printer is quiet
4.if the test page is still blank..u need another set of cartridges
5.if test page isn't blank and u print blank pages from computer,do the following:
6.if printer s/w is already installed..please go to devices and printers(printers and faxes in win xp)
7.please click on add a printer
8.select driver manufacturer as HP,and driver as deskjet 990c(this is the generic driver for all HP printers)
9.follow the onscreen instructions,and finish installation
10.try printing with this driver
1helpful
Error code Oxc 18a 0007 appears and can not print
The "Ox18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Hp deskjet 3650 printer works very slowly with win 7
tion one: Check the power supply Follow these steps to check the power supply to make sure that it is functioning correctly.
  1. Turn the product so that you can access the rear side.
  2. Unplug the power cord from the back of the product. Figure 1: Unplug the power cord from the back of the product
  3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
  4. Plug the power cord directly into a wall outlet.
  5. Print and time a self-test again.
  • If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet.
  • If the test page takes significantly longer than 30 seconds to print, continue to the next solution in this document.
Solution two: Check the USB connection
  1. Disconnect the USB cable from the back of the HP product. Figure 2: Disconnect the USB cable from the back of the HP product
  2. Disconnect the USB cable from the back of the computer.
  3. Wait five seconds.
  4. Reconnect the USB cable to the back of the product and the computer, according to the following guidelines: The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Connect the small end of the USB cable to the back of the product Connect the other end of the USB cable to the computer
  5. After you make sure that the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
    • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
    • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high-quality. Otherwise, HP recommends using a USB cable that is less than 2 m (6 feet, 6 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
    • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the problem.
    • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
    • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
  6. After checking the USB connection, print and time a self-test page again.
  • If the test page prints in 30 seconds or less , the problem relates to the USB connection. Replace the USB cable or modify the connection to meet the preceding criteria.
Solution three: Check cartridge compatibility Incompatible cartridges can cause the slow printing problem. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge in a language other than English, click the language link near the globe icon (c01906983.gif ) in the upper right corner of your browser. Examine the cartridges in your HP product, and then follow these steps to check which cartridges are compatible with your product. The number on the cartridge label must match the numbers listed on HP SureSupply.
  • If the cartridges are not compatible with your HP product , replace the cartridges. You can order replacement cartridges directly from HP SureSupply.
  • If the cartridges are compatible with your HP product , continue to the next solution in this document.
Solution four: Perform a reset A reset drains the power from the product and returns it to the same settings after restarting.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product. Figure 3:
  3. Disconnect the data cable (USB or Ethernet, depending on how your product is set up) from the back of the product. USB cable Ethernet cable
  4. Unplug the power cord from the wall outlet. Figure 4: Unplug the power cord from the wall outlet
  5. Wait about 30 seconds.
  6. Reconnect the power cord to the product and wall outlet, and then turn on the product.
  7. Print and time a self-test again.
1helpful
2answers
Cancelling won't stop printing -- blank pages with headers and foot notes
Dear, there is a printing command that is in the printer cache, and it is doing the job automatically. There will be a printer icon in the system tray at bottom right on the task bar of you computer, click on it, a dialogue box will appear with all the printing commands in the que and cancel all the printing commands in the que. and switch of your printer, re-start the computer. You problem will be resolved.
Best regards.
2helpful
This is for an HP Photosmart 3310 all in one. The display shows message Ink System Failure Error 0xc18a0206. Tried the troubleshooting steps on HP website: remove ink cartridges, unplug printer from...
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Hp photosmart A717 PRINTER WILL NOT PRINT TEST PAGE OR ALIGN PAGE A BLANK PAGE IS PUSHED OUT .ANY SUGGESTIONS.??? HERBERTD2005
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
2answers
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
k24674
ADMIN Andrew
ADMIN Andrew
