Introduction
There
are times when a partial reset may be required to restore the HP
All-in-One to proper operation. A partial reset does the following:
Reset the user settings to the factory defaults.
Reset the language and country/region settings on some models.
Performing a partial reset
Unplug the power cord from the HP All-in-One.
Wait for 20 seconds.
Press and hold
and
while plugging in the power cord to the HP All-in-One.
Release the buttons after the HP All-in-One starts up.
The HP All-in-One will now be reset to factory defaults.
Shut down the computer, shut down the printer and disconnect all the power cables and the reconnect the after about two minutes then turn on the computer and then the printer.
This model takes an extremely long time to shut down. I have had mine on for 2 years. because it takes way too long to start up and shut down. Still works fine.
If you really really want to power this unit down. Purchase a strip plug with power buttons for Monitor, CPU, Printer and Device 1 and 2. Shut down the PC normally then hit the Printer button on the strip plug. Viola printer off no worries.
I have hp printer model R45
I got scanner error and printer asked me to turn power off and on. I turn the power off/on. Its about a month the Problem has started
Please HELP
Thanks
amin
I had to turn off the printer & disconnect the power cord. I also had some material that was backed up on hold from the night before that was preventing the current material from being printed & I had to go in & cancel the documents to be printed before the printer would function.
Disable all the startup items and your security software and firewall. Then try installing the printer. If you still have the same problem try installing the printer by connecting to a different USB port. You can also uninstall all the USB port from device manager. restart the computer and then install the printer.
menu window shows "shutting down...." but does not respond to anything. We cannot even turn printer off. Will not respond to any key. Help.
(Plus we misplaced our manual!)
my problem is that my hp printer shutting down and we try turn it on
