20 Most Recent HP OfficeJet J4580 All-In-One Laser Printer Questions & Answers
you can disconnect the printer fron the power outlet and wait 5 min and reconnect.. if don`t resolve the problem you need to open the printer and find a smmal piece of paper jammed in the rolling. pls click if my solution was helpful and good luck
HP OfficeJet... | Answered on Jul 05, 2018
Good day,
The printerheads is located on the cartridges, so replaceing the cartridges will replace the printerhead.
Regards
Larno
HP OfficeJet... | Answered on Jan 18, 2018
lestave my j4580 trouble lt says ck blk cartrige
HP OfficeJet... | Answered on Nov 21, 2017
Sounds like paper not feeding in on time, usually should pop a code, but you could try cleaning paper feed wheel with something like light cleaner, not something strong.good luck
HP OfficeJet... | Answered on Nov 07, 2017
Clean the ink heads with the machines head cleaning programmes
HP OfficeJet... | Answered on Mar 05, 2016
It's a .tiff file. Some photo edit programs will own them. Also try inserting it in a blank MS Word document. Then print the document.
HP OfficeJet... | Answered on Sep 15, 2015
When you go to print out the document make sure you have selected to print in black and white
HP OfficeJet... | Answered on Jul 30, 2015
Is it already in windows print menu, otherwise install it , or look for the correct settings. The transport lock is removed?
HP OfficeJet... | Answered on Mar 04, 2015
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
HP OfficeJet... | Answered on Oct 09, 2014
From the service manual. Best to call a Ricoh tech as this is a component the uses AC voltage.
HP OfficeJet... | Answered on Aug 15, 2014
I suggest you contact HP Printer Technician, because if ink stuck in under rod than may be cartridge damage or any other printer device damage so not clear it. Better of contact local printer technician.
Thanks,
HP Printer Support
HP OfficeJet... | Answered on May 22, 2014
When you say it won't accept the cartridge, is this what you are seeing?
The Incompatible Cartridge Incorrect Print Cartridge or Print Cartridge...
HP OfficeJet... | Answered on May 08, 2014
There must be a way... Usually HP printers have schematic how it is to be done. Those are in a litlle book that came with printer.
HP OfficeJet... | Answered on May 04, 2014
HP OfficeJet J4580 All-In-One Laser Printer Logo
772 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
cartidge stuck in under rod want remove
  • Office Equipment & Supplies
