SOURCE: D link Router & my laptop
Debugging the issue -- this is not a solution.
Have you plugged a computer into the router if possible using an ethernet connection? Did it successfully access the internet?
If not the ISP (modem?) side of your router is probably configured incorrectly for your ISP
If that works wireless routers and adapters operate different bands I know of A, B, G and N. Do both your router and adapter card have at least one of those bands in common?
At any time have you attempted on the laptop to connect with the router? When connecting do you see your router by name? has your router been set to a unique name so you aren't confused seeing one of your neighbor's routers?
Did you enable encryption (WEP or WPA) in either the router or the wireless adapter and not enable it in the other?
Do you have MAC filtering on in you router and forgot to enter the wireless cards MAC accress?
Please reply with as many answers as you know and we can step through the process to attempt to complete the connection.
Also please provide the manufacturer and model for each of the following
Your router, your laptop and your network adapter
Please provide the operating system installed on your laptop,
If the wired connection to the internet does not work please provide the name of your internet service provider.
SOURCE: wireless connection showing acquiring signal - wireless not working
your should install the router once more , entry the username and passord provided by ISP. then your router will work properly.
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
first you see the in the internt explorer in that tools in that is give internet option in that connection>lan settings> if the proxey server is ther then remove it if not ther then go it. i think you get it.
second think is that in your dlink router reconfigure the router properly and give the isp details correct and one more thing is check the dns value.
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is [email protected]
SOURCE: D-Link wireless router,WBR-2310
First reset all settings of router to default.
You can reset it with RESET button it is in back side of router press It for 10 seconds.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then configure your router WAN settings as your internet service provider settings.
Go to wireless enable wi fi .
Then save all settings then check.
Also enable DHCP if you want ip addreses automatic from router.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
