20 Most Recent NetGear N150 RANGEMAX 150 Wireless Router Questions & Answers
2answers
Connecting netgear n150 to nintendo ds
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
1/21/2016 9:32:44 PM • NetGear N150... • Answered on Jan 21, 2016
Adding password
Are you referring to WPA-PSK encryption page 29 section 2-1 of user manual http://documentation.netgear.com/wpn824n/enu/202-10587-01/usermanual.pdf
3/11/2015 10:05:45 PM • NetGear N150... • Answered on Mar 11, 2015
How to connect my wi fi netgear 69 to my phone
Firstly what make and model is your phone?
12/11/2014 9:27:05 AM • NetGear N150... • Answered on Dec 11, 2014
Connecting dishnet to basic talk phone
Push the WPS on the router and then on the DISH allow time for it to sink.
8/2/2014 11:57:43 AM • NetGear N150... • Answered on Aug 02, 2014
There is no light in Netgear N150 Wireless Router
are sure its plugged in? is the outlet good? plug it in somewhere else, sometimes its a switched outlet you don't even know you have and you just have to flip the light switch you never pay any mind to. stuff goes bad, that router isn't that old... I see way older routers working fine.
11/22/2013 1:10:43 PM • NetGear N150... • Answered on Nov 22, 2013
Change pasword and name admin
its pretty easy, log in and go to admin tab if you don't know the username and password to start the hold in the reset buttons until all the lights flash at the same time a couple times and then let go. now the username and password are admin and password and you have lost all settings that were in your router such as wireless SSID and password, port forwarding, and static ip's... should have mentioned that 1st ;}~
11/18/2013 8:18:01 PM • NetGear N150... • Answered on Nov 18, 2013
I have a new Netear Router & I'm trying to hook up my Kindle which wants a password
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
5/27/2012 12:01:08 PM • NetGear N150... • Answered on May 27, 2012
Loss my netgear wireless security password,
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -http://192.168.0.1The default login = adminThe default PW = passwordYou can now change the default admin password and configurethe wireless settings.Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.Apply these settings to the wireless card in your laptop/computer.To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
5/16/2012 7:59:38 AM • NetGear N150... • Answered on May 16, 2012
Netgear cant connect to ipad
I think you should check the wireless settings of the router netgear router and the iPad .Do you have any other wireless computer or device in the network?Can you connect any other computer or device to the wireless network?If your wireless network is secured then make sure that you have the correct network key.See the links below:Netgear router setupHow to connect iPad to Wireless network
4/23/2012 11:09:33 AM • NetGear N150... • Answered on Apr 23, 2012
0answers
I lost my password how can I change it?
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
1/10/2012 5:45:18 PM • NetGear N150... • Answered on Jan 10, 2012
How To Connect With Mywifiext net Setup Page?
This sounds like an answer to someone's question? You need to click in the MY ANSWER box under the question. It doesn't work adding your ANSWER as a new QUESTION.
3/11/2023 6:13:39 PM • NetGear... • Answered on Mar 11, 2023
How to check netgear r7000 speeds ?
hi please find link for how to check speed https://kb.netgear.com/000038894/How-do-I-check-my-Internet-speed
11/25/2021 1:20:54 PM • NetGear... • Answered on Nov 25, 2021
How to connect PC to netgear WIFI extender
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
11/18/2021 3:59:41 PM • NetGear... • Answered on Nov 18, 2021
Belkin f9k1106v1 range extender not connecting
QUICK TIP: When finding a location for your range extender, it is best to place it within the same room as the computer. You can also use https://192.168.206.1 to access the range extender's web-based setup page. Step 1: Place the range extender in an area where the Wi-Fi signal of your router is strong, but near where you want to establish your extended network. Step 2: Plug in the power supply of the range extender and make sure that it is powered ON. Shortly, its light will begin to flash blue and orange. Step 3: Place your computer near the range extender. Also, make sure your computer is not wired to any other network devices. Step 4: Connect your computer to the range extender by opening the list of Wi-Fi networks and selecting Belkin.setup. Confirm that the list shows it's connected. Step 5: Open a web browser, enter https://belkin.range into the Address bar, and follow the on-screen instructions. Don't forget to type "http". Once the setup for your range extender is complete, you may connect the computer to its Wi-Fi.
9/12/2021 1:30:03 PM • NetGear... • Answered on Sep 12, 2021
How can i connect Netgear AC1750 Wifi Mesh Extender manually ?
By Following these steps you can easily setup your Netgear wifi range AC1750 extender
  1. Turn On Your Extender by plugging it into the power outlet, Wait till the extender is turned on and the power led light to stop blinking Once the device is fully booted up,
  2. Now open your web browser, enter mywifiext.net in your web browser if you are Are going to setup your range extender using the window device.
  3. Click on the New Extender Setup , Now Create a new account in case you do not have an account Already.
  4. Accept the term and conditions, Click Continue
  5. Now you will be asked whether you want to Configure your Netgear extender as a wifi extender or as an access point
  6. Click as a Wifi Range extender
  7. Now choose the network you wish to extend and click on the Next button
  8. Enter the password of your current wifi and click next
  9. Be Patience and wait for few seconds.
You had successfully setup your AC1750 Netgear range extender, in case if you are facing an issue with login into your Netgear extender read our extender login guide .
5/6/2021 2:30:13 PM • NetGear... • Answered on May 06, 2021
How can I check netgear extender firmware update version?
By following these simple steps you canupdate the firmware on your netgear Wi-Fi extende.
  • First of all, connect your extender to your router Connect to your extender's Wi-Fi network.
  • Visit at NETGEAR Suppor website
  • Enter your extender's Model Number or Product Name.
  • Click Downloads.
  • Select a firmware version and click Download.
  • Unzip the file if needed.
  • Enter mywifiext.ne. in your web browse.
  • Enter the extender admin user name and password.
  • Click Firmware Update.
  • Click the Browse button, then locate and select the firmware file that ends in .img or .chk.
  • Click the Upload button. The firmware update starts and the extender restarts. The firmware update process takes about two minutes.
If you still face any problem so you can watch this video :-
4/29/2021 7:59:20 AM • NetGear... • Answered on Apr 29, 2021
How do I manually update the firmware on my NETGEAR WiFi Extender?
By following these simple steps you canupdate update the firmware on your netgear Wi-Fi extende.
  • Click Downloads.
4/26/2021 3:31:43 PM • NetGear... • Answered on Apr 26, 2021
2answers
Cannot connect to NETGEAR_NET
https://www.google.com/search?q=NETGEAR_NET&oq=NETGEAR_NET&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
4/8/2021 5:55:57 AM • NetGear... • Answered on Apr 08, 2021
NetGear N150 RANGEMAX 150 Wireless Router Logo
20 questions posted
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
connecting netgear n150 nintendo ds
  • Computers & Internet
