20 Most Recent D-Link DP 301P (DP-301P) Print Server Questions & Answers
SIMPLE SOLUTION:
Get your computer in the same subnet as the printer, then paste this line in your web browser, replacing the IP address of your printer. Your password is now "password"
http://192.168.0.10/ReplyC.htm?SRV_Name=PS-5642D6&SYS_Location=&ADM_CONTACT=&Sys_Password=password&Verify_Password=password&PS_Portname%281%29=PS-5642D6-P1&PS_Descrip%281%29=&PS_Speed%281%29=High&PS_PJLPrinter%281%29=No&Config1=Save
D-Link DP 301P... | Answered on Aug 16, 2019
The IP address is configured through your DHCP server in your router. You're going to have to either look in your router for connected devices or use a tool like netscan.exe (free) to find the assigned IPs in your network, If you don't have too many connected devices, you can keep putting the IPs that are there into your web browser until the device page comes up. They SHOULD HAVE put a reset button on this thing, but they didn't.
D-Link DP 301P... | Answered on Jan 31, 2014
I have D link DP- 301P Print server I am using it in Epson M188D Printer for KOT Printing but its shows some times printer not found on network, please help me to solve the problem.
Ajay
D-Link DP 301P... | Answered on Jun 07, 2011
There are two steps that we can suggest,
A)
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
B)
On the back of the print server you will find a pin hole, insert a paper clip for 30 secs with the print server powered on. All lights will flash. Try to setup the server again.
Hope this helps.
Regards,
Shrey
D-Link DP 301P... | Answered on Jun 01, 2011
I am looking for a solution as well. Some have said to login as psadmin and use SYSXXXX (XXXX being the last 4 of the mac address: ie. AA:3S:33 the password would be SYS3S33)
This did not work for me.
Even with the PSAdmin software, it requires a password to reset to defaults or to change the current password,
D-Link needed to put a reset button on this unit - this is stupid.
I will post if I find an answer.
D-Link DP 301P... | Answered on Mar 07, 2011
viaujocposted a brilliant solution which worked for my DP-300U: see http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
To paraphrase,
First try logging in with the following
username: psadmin
password: SYSXXXX
(where XXXX is the last four digits of the mac address)
If it works, you can proceed to reset the password.
Alternatively, you may be able to extract the original password from a configuration backup, if you have one. For details, see http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
D-Link DP 301P... | Answered on Feb 09, 2011
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
D-Link DP 301P... | Answered on Jan 11, 2011
you need to change it to 192.168.0.0 - try that - it is the default address of the units.
Gary @ Fix Ya
D-Link DP 301P... | Answered on Dec 20, 2010
Use PS-Link software in the software CD...
D-Link DP 301P... | Answered on Jul 22, 2010
hi
i forgot password Printer Server D_link Dp-301p
Please Help Me
D-Link DP 301P... | Answered on Jul 18, 2010
D-Link DP 301P (DP-301P) Print Server Logo
47 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DP D-Link
  • DP D-Link
Most Popular Question
change ip address
  • Computers & Internet
