20 Most Recent
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Questions & Answers
RE: ADSL2+Modem. I'm able to do your quick
Lynne,
First you need to delete your phonenumber from this post. This is a public post accessible from all over the globe.
Second you need to contact your ISP with this problem. It might be that your ADSL modem isn't compatible or wrongly configured for your present connection.
I don't know my security
Go to My Documents, there you should find an icon for wireless settings. Click on wireless settings, you'll find the security key.
How do I connect to wireless internet from laptop
Look under network connections and open wireless connections. Then look for you router SSID (network name) and the press connect button. If password/key is needed enter that at this time. Make certain your laptop wireless is turned on - some have an physical on/off switch.
D-LINK G624T after saving parameters doen't answer
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
D-link router power light is red
Red flashing light on D-Lonk wireless router dsl-2750b
Means you have no internet connection. Try a new LAN cable between you router and internet modem. Connect directly to you internet modem make certain it is working. Reboot both devices.
Problem with DSL2640U wireless router
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Which is the latest firmware
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Router won't recognise my new Kindle
First try rebooting the router to see if it "see' the kindle. Make certain use are using the correct network password/key - it is case sensitive. Does the Kindle connect to other WiFi networks? If not the Kindle may be the issue
The ultimate answer is a factory reset of the router.
GLB-802C new firmware
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
