20 Most Recent D-Link DIR-615 Wireless Router Questions & Answers
If you have a hard connection that is you have a cable to your router you can go to Dlink's site and watch the setup videos if you are not savvy with technical terminology.
there is also a site called Ehow that will educate an well as show how to utilize the wireless setup you have .
Please provide your model number , Operating system and more detail as to the issue you have so we can further assist you properly.
D-Link DIR-615... | Answered on Jul 16, 2019
If the power pack is good then the router is dead and needs to be replaced. It's generally cheaper than trying to fix it.
D-Link DIR-615... | Answered on Aug 16, 2018
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of your router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
D-Link DIR-615... | Answered on May 18, 2018
Have you checked the IP settings on your internal network. It sounds like you have 2 identical IP numbers.
D-Link DIR-615... | Answered on May 29, 2017
If you have not set a password on it, then the default for most dlink products is User: admin and Password: admin.
If you have set a password on the system then this will not work. You will need to reset the router. You do this by pushing in the reset button on the back of the router (usually with a pen or paper clip). Do this with the power on and hold the button in for about 30 seconds. This will reset the router to factory defaults.
Hope this helps
D-Link DIR-615... | Answered on Apr 28, 2017
This is your WiFi network password/key
D-Link DIR-615... | Answered on Jan 07, 2017
Login to the router wireless section (using a LAN cable and change the password.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
D-Link DIR-615... | Answered on Jan 06, 2017
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
user ADMIN for login and leave password blank then you can connect using the wizards.
If a hard reset does not fix, then your electronics may be bad.
1,128 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
please postal code cape town
  • Computers & Internet
