20 Most Recent Linksys Wireless-G WRT54G Router Questions & Answers
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Linksys... | Answered on Jan 31, 2019
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Linksys... | Answered on Nov 26, 2018
I am providing you with two links from linksys. The fist link is the user guide, and the second is the quick installation guide. Between these two guides you should be able to set the router up with out any issue.
http://homedownloads.cisco.com/downloads/userguide/1224638367343/WRT54G-v1.1_ug.pdf
http://homedownloads.cisco.com/downloads/quickinstall/1224638367420/WRT54G-v1.1_qi.pdf
hope these help
Linksys... | Answered on Nov 22, 2018
You might be getting intermittent connection. What is the exact model and version of your router? check your firmware. It might need to be upgraded. =)
Linksys... | Answered on Sep 12, 2018
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Linksys... | Answered on Sep 07, 2018
If the first solution did not help, try calling Linksys Tech support or try this http://technicalsupport.blog.friendster.com
Linksys... | Answered on Aug 29, 2018
Linksys Routers are one of the best Home wireless routers. it has good security feature and better wireless length. To change the Upnp setting on your router
follow these steps
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1).Press Enter.
Step 2 The default username is admin (all lowercase) and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab then click Misc. to the left.
Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wirelessrouter, or select Disabled using the radio buttons to disable it.
Step 5 Click Apply and then click Continue to save the new settings.
Read more for setup linksys router
How To Setup Linksys Wireless Router In 5 Min Fixingblog com
Linksys... | Answered on Aug 28, 2018
Normal!
Wired connections are faster than equivalently wireless connections (from/to the same node) and so your
experienced is quite normal.
Additional nodes divide the original bandwidth and denigrate the performance, which is why one tries to
maximize the original bandwidth (speed in MHz) of the connection to the gateway.
You can maximize your experience by having critical systems wired to the router, and this also provides
greater security than any encryption (which is another brake on your speed) necessary for a wifi
connection.
Make sure you have the fastest possible wifi card in your portable devices to maximize your speed.
Linksys... | Answered on Jul 12, 2018
Hello
Try a different wall plug.If this does not bring the light to green the you probably need a new power cord.
Here is a link for your router.
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
Linksys... | Answered on Jul 10, 2018
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Linksys... | Answered on Jul 05, 2018
After reformatting your dell 8400, did you reinstall all drivers of your devices? The linksys router won't be affected by the reformat. Your computer should still get connection from your router. This is a dell issue. If you have another computer connected and working with the router, that means the router is still functioning. Call Dell or linksys technical support. If they cannot help try this http://technicalsupport.blog.friendster.com
Linksys router not support to work with landline.
Linksys router only can work with cable internet.
wat about the powerlight in the router....
Linksys... | Answered on May 18, 2018
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
No, but you can just reset the whole router and start from scratch. Hold the reset button on the rear of the router for 60 seconds and your will restore the unit to defaults, at which point you just need to reconfigure all of your configuration settings and password, as well as your wireless access code. Let me know if you require any additional assistance.
Linksys... | Answered on Mar 31, 2018
Resetting the linksys router in just six easy steps..
1. Turn on the router.
2. Reset the router, wait until the power light is blinking and then press and hold the reset button for 10 second.
3. Turn off the router and turn on again.
4. Wait for the power light to stop blinking, if the power light does not stop blinking, turn the router off, wait approx 30 second , and then turn it on again.
5. Connect the router to your computer, when it is connected to a computer with an ethernet cable, the ethernet port light will light up.
6. Connect the router to your modem, the modem is connected to the internet port is your computer. The router is connected to the modem.
If you are not able to reset the linksys router password then call linksys router support phone number 1-888-494-1155 (Toll-free) USA.
Linksys... | Answered on Feb 12, 2018
Are you trying to open the router setup page? Make sure that your computer is connected to the router on LAN port. Check the IP address on the computer and Default gateway. Default gateway is the IP address on your router.
Try this link
Linksys WRT54G router setup and troubleshooting
Linksys... | Answered on Jan 03, 2018
Make sure that computer is connected to the router on LAN port (1, 2, 3, 4). Also check the ethernet light is also lit on the router. Check the IP address on the computer connected to the router. Check this link
192 168 1 1 How to set up
Linksys Wireless-G WRT54G Router Logo
4,209 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
change upnp settings router
  • Computers & Internet
