Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&cc=us&lc=en&dlc=en&product=3645100&tmp_track_link=ot_search
Please follow this link and well you would have your ink cartridges replaced without a problem.
Otherwise this is what you do
Step one: Remove the old cartridge
Step two: Prepare the new cartridge
Use the following steps to prepare the new cartridge for use in the HP product.
Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, right-click this link, HP SureSupply , and then click Open in New Window . If your language or country does not display nextHow do I remove and - c01906983.gif icon ( ) select your language and location.
Step three: Replace the old cartridge
Use the following steps to replace the old cartridge.
Step four: Place the unused cartridge in a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a black cartridge in order to install a photo cartridge), put the cartridge that you are not using in a cartridge protector.
NOTE:
Cartridge protectors come only with photo cartridges. If a cartridge protector is unavailable, store the unused cartridge in a rigid, airtight container (not a plastic bag). If unprotected, the cartridge can dry out and become unsuitable for use.
Step five: Align the new cartridge
The HP product prints a cartridge alignment sheet when you install new cartridges.
Please check the link and you will see on how to replace ink cartridge of HP J4580 Officejet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&lc=en&dlc=en&cc=us&product=3645100
Thank you and good luck!
SOURCE: Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
