20 Most Recent
HP DeskJet 842c InkJet Printer Questions & Answers
Prints jibberish
Hi Anna,
This is because of corrupted Printer Drivers. You have to uninstall and reinstall your Printer Drivers. Either from the Printer disk or from
www.hp.com website.
Regards,
Sean
Printer wont print black, it
printing in black* change the properties of your printer --->> Printer icon-->>Properties-->> select color or black and white grayscale.fading print*clean the cartridge printhead through the computer or manually (remove cartridge and wipe with cotton cloth with water). Also, clean the scanner window (glass). http://printerquickfix.blogspot.com/
HP842C continues to print with nothing on the
Check your Catridges, they might be dried up if new, or empty, Remove them shake them to feel a presence of ink or tap them on a piece of paper to verify if ink will comeout if not then they are empty and need to be replaced they they have a bit of ink you need to shake and try printing again if this persists change the catridges, also make sure that the Printer is Clean, verify the Catridge Carrier for any dry ink deposits.
If printer runs out of paper and you refill starts
The continuous printing issue can be fixed following this link
http://www.fixya.com/support/r5095488-unable_print_hp_printer
Regarding Gibberish printing or say garbage printing, If the above utility does not fix this issue, probably the printer drivers are corrupted, and you may have to uninstall the printer software from your pc and download and reinstall the latest drivers. this link below will let you choose the operating system of your PC and download the drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=60426&lc=en&cc=us&dlc=en&lang=en&cc=us
My deskjet 842C will not print in color
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
