Washing Machines Logo
Posted on Sep 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
Anonymous
Level 3:
President:
  • Master 1,932 Answers
  • Posted on Sep 08, 2010
Anonymous
Master
Level 3:
President:
Answers
1932
Questions
0
Helped
519559
Points
6158
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
puggy
8helpful
Hotpoint washing machine model WF620, keeps reading TEST when you select the programme.
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Noisy when spinning
bearing gone cheaper to buy a new one
1helpful
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
2answers
10helpful
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Hotpoint wf620 aquarius very noisy and not letin any water in
A washer usually shakes or vibrates when it isn’t sitting firmly and level on the floor or because it has an out-of-balance wash load. First eliminate the possibility of the latter—adjust the load if it has scrunched up on one side of the tub. Then check the machine for solid, level support. For the machine to work properly, the floow must be flat, level, and strong enought to support the heavy, water-filled washer without deflecting under the load.
1) Unplug the washer.
2) Look under the washer, and make sure all feet are resting firmly on the floor.
3) Make sure the front legs have locking nuts to keep them tight and that the legs have rubber caps. If they don’t, buy these parts and install them.
4) Make the front feet as short as possible by screwing them up into the machine. Place a level on top of the washing machine and adjust the front feet slightly if needed to level the washer; do not fully extend them.
5) If necessary, tilt the washing machine forward. This will let the back feet self adjust. Recheck for level, and adjust the front feet again.
6) Plug in the machine, and run it empty through the spin cycle to see if it still vibrates.
7) If it does, call a repairperson or the manufacturer to ask about solutions.
Thanks for your question
2helpful
Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
1helpful
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
