20 Most Recent
Hotpoint Aquarius WF220 Front Load Washer Questions & Answers
Limited water supply in summer (off mains) - water usage?
Your machine will not function till the right level of water is put into it automatically from your inlet source; it varies depending on the programme. The only thing you can do is to see that the mesh in your inlet pipe is not clogged; pressure should be good too at your wall faucet. You are welcome, also you can rate me good, thk u.
6/5/2016 6:51:45 AM •
Hotpoint...
Answered
on Jun 05, 2016
How to fit a belt
Remove the lower rear panel of the washer and the top cover also.
Tilt the washer forward, and from the top fit the belt round the motor pulley first, and slowly feed it round the drum pulley, turning the drum pulley at the same time.
Watch your fingers as the belt will be very tight and difficult to get round the pulley.
but this is the best way to do it, trust me on this.
If it comes off, just start again., once you have the belt on, you can then easily align it up properly on the 2 pulleys.
4/13/2015 10:59:54 AM •
Hotpoint...
Answered
on Apr 13, 2015
Door locked not open by hand
hi take top off door works on water presure normally clipped to side at top you will see a round or oval part with wires plugged in look at bottom of that there is a clear tube take it off by sqeezing clip pull off open door and put it back or else machine will just keep filling try back soap tray
2/17/2014 1:21:43 AM •
Hotpoint...
Answered
on Feb 17, 2014
Aquarius wf620 super silent washer has "test" in
- to de- activate press and hold the start/cancel button untill all the lights come on.
- then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
7/22/2013 8:11:55 AM •
Hotpoint...
Answered
on Jul 22, 2013
Bearings drum
Replace the bearings.... the only solution the machine will have a new lease on life.
5/28/2013 11:41:25 AM •
Hotpoint...
Answered
on May 28, 2013
Hotpoint wf220 glass door
undo door hinge from cabinet - held with two screws.
the door halves are held togethet with a few screws which undo and the door will split apart so you can replace the glass
5/22/2013 5:22:47 PM •
Hotpoint...
Answered
on May 22, 2013
