Reset it and try again go to the main menu>setting>reset all ok.If u are saticfied with my information then vote me for more solution.Thank you for visit.
Operation failed either the application doesn't work with your phone or the the game application is corrupted with virus that needs to be deleted before it affects other applications..
It is corrupted. Use your data transfer cable for your pc. Connect it and remove the folder then transfer on again. To remove make sure you right click in the task bar, safely remove hardware. Not doing this can corrupt your pc's or the devices memory.
i once had a similar proble m which sony ericsson people declared as virus which affected the phone software......they just re.installed my software problem was cleared .....not a serious problem...just do it in a authorised center thats all.
i have the solution for ur problem first u'll have to download the update software program from sony ericsson official site then you'll download a program called xs.open www.4shared.com write in the search k850 fbn and k850 mbn download both of them then open the xs program press connect switch off ur mobile press c connect the mobile with the computer with the usb while pressing c button then click flash then in the flash firm ware click browse then put the mbn that u downloaded and then flash system put fbn then click ok wait abt 5 min. after finishing all of this u now have a new software but to make sure this is the right software open the updater program that u downloaded from sony ericsson follow the instructions then this problem will be solved N.B u need to back up ur data mssgs conatcts and stuff using my phone explorer software.
to solve this problem u just have to update the sony ericson software from below link. http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w610i?lc=en&cc=us
but make sure u back up all contacts files and everything before updating. just follow the instuctons and it will be fine.
Got same problem :'(
