20 Most Recent Sony Ericsson W850i Cellular Phone Questions & Answers
you can download the games and copy then into your games folder when you do the file transfer when the phone is connected to the pc.
Sony Ericsson... | Answered on Jan 29, 2019
Friend, W-850 is CID based phone. You have updated it and it got it's original flash which was generated for it. Now u have to unlock it again. You see, this all are happened due to special security of CID chipset. You should not update it but when u do that now unlock it. Go to technician who got SETOOL, CRUISER BOX or any other comapitable unlocking tool. He will charge you little. Find the servicemen arround you on FIXIYA and thanks FIXIYA for solution ( Only if u find it helpful)
Sony Ericsson... | Answered on Sep 05, 2018
you can try but phone ime on blacklist
Sony Ericsson... | Answered on Jun 16, 2017
Was the phone locked? Or the SIM card?
Because if the SIM card was locked then type in 3 times a wrong pin, then they'll ask you for a PUK code, call your service provider and ask them for your PUK code.
If the phone was locked- in other words, you put a pin to prevent people from using your phone by changing SIM cards- then I'm sorry I can't help you.
Sony Ericsson... | Answered on Feb 13, 2017
from my own experience and idea, I think that flashing light indicates low battery.
This is usually common with Sony ericsson phone, it flashes a red light once battery is low and you want to power is on.
Maybe should test your phone with another battery.
All the best.
Sony Ericsson... | Answered on Jan 10, 2017
sorry to tell you but water damage in a phone is like cancer
your phone will eventually die from it
Sony Ericsson... | Answered on Oct 17, 2016
Make sure you have a you tube downloader, then download it to your pc, then download it using a data cable or bluetooth device, make sure you convert the video first in a supported format of your celphone, after downloading it from you tube.
Sony Ericsson... | Answered on May 04, 2015
Yes the problem is coming from the speakers , so take the phone to a repair center and have them replace the speakers for you.
Sony Ericsson... | Answered on Apr 07, 2015
Firstly, did you try removing the battery from the phone and leaving it out overnight? This might solve you white screen issue. Secondly, is your phone able to boot into file transfer mode? The final solution would be to flash your phone to fix the firmware and then you will have access to your data. Here is more info:
http://www.mobileviking.com/archive/2007/09/24/Reviving-my-almost-dead-Sony-Ericsson-K800i.aspx
It talks about the W850 but it applies to the K800 as well. Good luck.
Sony Ericsson... | Answered on Mar 23, 2015
Dear Friends,
I have the same problem (Application is still running close it and start the camera) from last Week onwards, i went to the sony ericson service station, they told some Part(board) to be replaced and It will take 15days hardly,I dint accepted his comments, Then i worked full fledged on this and i got the solutions,
Solution:1(model:W580i)
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Solution:3
Throughout all the mails regarding that error messages using Googles Search
Don't go Mobile service stations without knowing a nature error, because they ready to cheating us. Becareful.......... Freinds
Any queries,
Call me on my hand phone:
My Number: 9940097172
Rgds.,
Nagoor
Sony Ericsson... | Answered on Nov 25, 2014
What is the question?
Jack
Sony Ericsson... | Answered on Jul 14, 2014
1. It's a common problem with Sony Ericsson W850 phone!
2. It displays the 'Emergency Calls Only' message even the network is available. (Mainly due to the change in the frequency of the signals!)
3. You should try to update the phone OS/Firmware.
4. If it don't helps try to reinstall the OS software!
please rate this advice if it helps...tc! :)
Sony Ericsson... | Answered on Jan 27, 2014
Sony Ericsson W850i Cellular Phone Logo
987 questions posted
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
will not download games
  • Cell Phones
