20 Most Recent
Sony Ericsson W200i Cellular Phone Questions & Answers
Phone Unlock
i need to unlock my sony Ericsson's so i can use it on other networks? anyone no how?
What is Unblock code for w200i
dear shir ! my name shiyam i buy new mobile phone sony ericsson i put lock coad in my phone after that i forget that now i want to open my phone please help me.
Unlock sony ericsson w200i
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the network that the phone is locked on, and the country you’re in. Then I will give you the codes.
How to download game in w200i
SonyEricsson W200i is good all around phone for a good price, very easy
to use, some good features, good quality camera, great clarity, very
good quality sound.
To download free games you can use your computer or WAP download directly to your Sony Ericsson W200i cell phone.
I found a link to Free Sony Ericsson W200i games
http://www.mobilerated.com/sonyericsson-w200i-games.htmlhttp://www.blue-devices.com/
Gprs setting
go to settings->connectivity
change internet settings,streaming settings,Java settings in such a way that three are same Either airtel live/mobile office
Master code of sony ericsson
If you know pincode then it iTry Master Reset Code here possible otherwise you have to install its software for unlock.
Try Master Reset Code here http://www.unlocking4u.com/unlocking-services/rs6wp6/ For Your Model Mobile in the list.
OR:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
or:
Contact your service provider to get a master reset code at free of cost.
How to lock my folders in sony ericsson w200i
As a default sony ericcson doesnt provide any such module or application to lock the folders. But still Java softwares are available in internet in JAR format.
Download this JAR file from internet & store it in your mobile memory card & then install it in your phone.This application will help you to lock the folders or files.
Feel slow
you can try flashing the phone's firmware to correct this issue...........take it to a mobile shop and have it flash
Slow processing of internet
dear,
install the opera mini on your phone ..
get it from
www.getjar.com , then it will solve your problem
its a brower, that run fast. fast speedy..
regards,
dont forget to rate it
How to transfer vedios and music frm phone to computer
Not sure on the Windows issue but...Your phone has a port for a flash card called a Memory Stick PRO Duo™ support (up to 4GB) (you may need to purchase seperately) Transfer the data to the card then use a card reader to download to the PC.
How do i unlock Sony w2oo after synchronization?
1. Turn on the your phone whithout sim card
2. Lock screen
3. Press sequence: Menu, Back, Back, Menu, Back, Menu, Menu, Back
4. Select Service info
5. Select SimLock
6. Check where is X
7. If X is on NETWORK and value is difrent than zero, you can unlock phone.
8. If it is zero unlock by code is NOT available. The counter is blocked.
1. Turn on the phone whithout sim card
2. Type *#*#7378423#*#*
3. Select Service info
4. Select SimLock
5. Check where is X
6. If X is on NETWORK and value is difrent than 0, you can unlock your phone.
7. If it is 0 unlock by code is NOT possible.
How to unlock Sony Ericsson W200i Walkman sim unlock net
