20 Most Recent
Sony Ericsson K790i Cellular Phone Questions & Answers
K790i charging error stop charging
Hello Friend::::First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
I m not able to
sir in your cellphone the application and game software has been correpted.service your cellphone in the sonyericsson service center they will re-install the new application and game software to access the folder.................
"no network coverage" showing on
Goto Menu-Settings-Connectivity-Mobile Networks-Search Mode. Change your setting here from manual to automatic. Restart. If it does not work. Select your network in manual mode. In manual mode it will show all the mobile networks available in that area.
sonsunny
How to get Sony Ericsson
download PC Companion from this site and read installation instructions and how to use:
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/pccompanion/k790i?cc=pk&lc=en
