SOURCE: Kingston 8GB Pen drive
Write delay failed...
That is a sign of corrupted memory. Try to run a scan disk on it.
Assumed: Drive letter for the pen drive is G: (If it is not f then replace G with the correct drive letter)
Start > Run > CMD (Click ok, if done proper you will get a black box)
in the black box type in:
chkdsk f: /f /r /x
It will really look something like this
C:\Documents and settings\Administrator\chkdsk G: /f /r /x
SOURCE: Microsoft Windows 98 for PC Problem
Error SU0013 This error can also occur if you try to install the retail version of Windows 95 over an existing installation of OSR2 on a hard disk using the FAT32 file system. This error message can also occur if you have a FAT32 partition and you are installing Windows 95 (retail version), which only expects FAT16. This error can also occur if you are running EZ Drive and you have the Floppy Boot Protection option enabled in EZ Drive. You should be able to resolve this error by disabling the Floppy Boot Protection option in EZ Drive. The third-party product discussed in this article is manufactured by a vendor independent of Microsoft; we make no warranty, implied or otherwise, regarding this product's performance or reliability.
Setup could not create files on your startup drive and cannot set up Windows. If you have HPFS or Windows NT file system, you must create an MS-DOS boot partition. If you have LANtastic server or SuperStor compression, disable it before running Setup. See SETUP.TXT on Setup Disk 1 or the Windows CD-ROM.
SOURCE: Intel 845 GVSR drivers for windows vista
install this version of driver... it works for 845gvsr!!!
but the only problem is it does not give aero look, as we have only 64mb graphic card (internal), and vista needs 128 atleast,
Microsoft Windows* 2000
* Microsoft Windows* XP
* Driver Revision: 6.14.10.4342
update the bios and go to intel website and download the latest drivers r wisite driverguide.com and download the drivers
any dought mail me @ [email protected]
SOURCE: usb ports not working
All the USB ports were working before he installed SP3 and rebooted. After that only the mouse/keyboard ports worked. Same thing happened to me. No other changes were made, so something added/change by SP3 is the culprit.
Questions is...what did SP3 do to break USB and how to fix it?
